I just got my wife a Biria Easy Boarding Easy 7 bike, she loves it and it is clear that the Dahon Briza that I put a TSDZ2 on will no longer be a regular rider for her. In fact she wants me to remove the mid drive and restore bike to stock so she can easily put it in her small SUV to take to rides with her friends - they only ride slowly on paved flat paths.
Right now she doesn't even want an assist for the Biria but eventually she will for hillier paths than what she has tested the bike on. The Tongsheng won't work on her new bike.
I have a MXUS 36v geared front hub motor that I have taken out of the 26" wheel that it came with and laced it into a 16" wheel to try on a BOB type trailer. That was just messing around so I want to re-lace it into the original 26" wheel again and maybe try a better controller to see if the motor can provide better assist on steep hills than I found it to provide in the past.
I'd like to use WP connectors instead of the standard automotive type connectors that it currently has - anyone do this? Would cut and splice be the best approach or has anyone opened a motor and switched the wire loom completely? If I change the wiring loom to the motor to WP then I can use a KT WP controller and peripherals.
When I removed the motor from the original wheel I didn't realize that it had two different length spokes (7mm difference). I thought the rim was centered between the motor hub flanges but now not sure if the shorter spoke length is used on the left side to pull the wheel toward the disc brake side or if the shorter spoke just alternates with the longer spoke on the same side of the hub (longer for the spoke that laces with its head on the inside surface of the flange, shorter for alternating spoke with its head on the outside of the flange. I've laced a few wheels over the years but don't recall if the alternating spokes are different lengths.
