Snookguru101
- USA
I'm new to this forum so hello to all you ebike owners. I purchased a rattan Challenger Pro with I-Pas technology. Received bike and assembled bike. While I was doing that I had plugged my battery in to charge. But the light stayed green on the charger. So I touch the battery indicator lights on the battery it says fully charged. When I plugged the battery on the bike and turned on my LCD screen it showed a full battery. So I went through the initial setup with the LCD screen. Road the bike on a paved Road for initial test everything seemed fine. I I did some fine-tuning when the pedal assist adjustment. Went back out to ride everything function fine later that evening I take it for a ride get about a hundred yards away from my house in the battery indicator on my LCD screen started dropping dramatically to the point where it was flashing saying that battery basically. I stopped the bike and test the battery push button indicator and it says I'm only lost one light so basically I have 70 to 75% of the battery remaining. So I shut down the LCD screen cutting the bike off waited a few seconds powered it back on it showed three-quarters of a battery on my LCD screen so I start and drive away a hundred yards later it starts to do same thing rapidly drops and then starts flashing basically saying zero battery power on this LCD screen. The bike still functions when the LCD screen indicator is telling me the battery is empty. Here's the issue I bring it home go to plug in the charger my charger stays green and does not charge the battery. Initially when I got the bike the charger would not plug into the battery I had to call them and wait 4 more days for an adapter to come in the mail. So my battery is not taking a charge. I tested the battery it says 47.5 volts. I tested my charger my charger is fluctuating all over the board it's not pumping 54.6 volts like it should. So you think that would be the issue. I have another charger 48v 3amp charger I test it it's putting out 54.6 volts I plug it into my battery does not change the light over to red it stays green and will not charge my battery. This charger I take it in the other room plug it into another ebike which is a Sonders my roommates bike. And it functions properly and charges that ebike. that same charger will also charge my other friends ancheer when he stops by so I know it works. Just not on my ebike any help out there would be highly appreciated
