So I had my CCX since December of 2018 & commute 32 miles roundtrip daily year round. This happened to me today on the last commute of the year. There were signals leading up to this, but today the connection finally totally crapped out & after taking the battery off saw this. Trying to think of ways to salvage this with little downtime & expense like maybe swapping with connectors from CC or direct wiring. And also wondering why this happened.
Kind of messy log I tried to keep.
| 2/1/2019 | Gouge in chainstay near rings from chain suck |
| 2/1/2019 | Quarter size minor inward bend on rear rim edge |
| 3/1/2019 | Chain replaced one model up to KMC x9.93 |
| 3/22/2019 | Flat tire cleaned wheel put in 3 oz sealant |
| 3/24/2019 | Bent back warpage on rim wall |
| 4/3/2019 | Battery interface loose resulting in power loss |
| 4/5/2019 | Discovered that front wheel axle is M10x1 |
| 5/10/2019 | Battery returned fixed after over two weeks |
| 6/7/2019 | Brake pads worn |
| 6/7/2019 | Rear brake need bleed |
| 6/5/2019 | Notice signs of cracking near nipple holes rear rim. |
| 6/18/2019 | Brake pads front & back replaced |
| 7/10/2019 | Potential leak in rear brake lever |
| 8/19/2019 | Motor engagement & grinding noise |
| 8/30/2019 | Motor engagement & grinding noise during Critical mass ride |
| 8/20/2019 | Contacted Juice about above potential problem |
| 10/15/2019 | Replaced Chain |
| 10/18/2019 | Brake pads front & back replaced |
| 10/18/2019 | Have only experience above grinding noise once since reported. Motor does sound a little louder |
| 10/25/2019 | On 4th odo reset at 1600 miles each |
| 12/13/2019 | Left body separated from spindle Crank Brothers Doubleshot 3 |
| 12/11/2019 | Display to wire harness threaded connector worked loose & powered went out during commute |
| 12/16/2019 | Cracking at nipple holes more evident but not pulling out yet. |
| 12/13/2019 | Rear brake bleed not needed but rear lever travel screw needs loctite |
| 12/15/2019 | Moving rear wheel turns on light acting like generator while bike off |
| 1/3/2020 | Put on new Rock Shox Paragon Gold RL |
| 1/3/2020 | Added neoprene fork boots. |
| 1/13/2020 | 5th ODO reset (8000 miles) |
| 2/4/2020 | Replaced clutch/gear assembly |
| 2/10/2020 | Shimano BB UN55 68x127 installed in December stripped loose BB & shell threads during commute suspect not enough thread engagement because of 5mm worth of washers |
| 2/10/2020 | Reinstalled OEM BB for time being |
| 2/13/2020 | Installed YST Threadless Repair Bottom Bracket |
| 2/18/2020 | Put CC motor shell & rim on CCX motor internals until new rim can be laced on CCX motor shell. |
| 2/20/2020 | Time to replace chain |
| 2/27/2020 | New chain installed notice skipping in 11t cog. |
| 2/29/2020 | Brake pads front & back replaced |
| 3/9/2020 | Replaced stock 11t cog with 11t XT M760 Cog |
| 3/25/2020 | 6th ODO reset week of 3/29 |
| 4/20/2020 | Replaced derailleur cable & swapped to Shadow Deore derailleur from CC. |
| 5/5/2020 | YST Threadless Repair Bottom Bracket came loose |
| 5/6/2020 | Retightened repair bottom bracket |
| 5/22/2020 | Rear brake feel detent & occasional motor high frequency vibration noise. |
| 5/26/2020 | Rock Shox seal popped off air side commuting home reseated during ride |
| 6/4/2020 | Bled rear brake & it no longers sticks |
| 6/10/2020 | 7th ODO reset (11,200 miles) |
| 6/12/2020 | Replaced clutch/gear assembly - clutch was locked up |
| 6/30/2020 | Freehub sounding gritty after ride through flooded sections of road. Put in triflow through front of cassette & some behind |
| 6/30/2020 | Installed new brake disc pads front & rear |
| 7/8/2020 | Applied purple threadlocker to rear brake lever screw. |
| 7/9/2020 | Lower leg service on Rock Shox Paragon replaced oil, but kept seals & foam inserts. |
| 7/13/2020 | Removed & cleaned cassettte at work due to needing extra leverage with shop tools to get overtightened lockring off. Put light oil in back & front of freehub while cassette was off & no change in gritty sound. |
| 7/10/2020 | Replace unreliable CCX OEM rear light with B&M Topflight Senso. |
| 7/16/2020 | Purple threadlocker didn't work trying blue material insensitive |
| 7/23/2020 | Clutch slippage felt. |
| 7/28/2020 | Put 3oz Orange Seal in rear tube. |
| 7/31/2020 | Chain jump high speed bump |
| 8/4/2020 | Clutch seized |
| 8/5/2020 | Clutch seems to have un-seized itself. |
| 8/9/2020 | Swapped to OEM Kenda rear tire after sidewall/bead 1" bulge discovered in Marathon Plus likely from riding flat. |
| 8/20/2020 | Rear flat & Orange Seal Endurance did not seal on a nail but leaked out of tube into tire. Will try regular Orange Seal next. |
| 8/21/2020 | Coming up on 8th ODO reset. |
| 8/21/2020 | Rear wheel noise for over two weeks now. Suspect lack of tension spokes. |
| 8/25/2020 | Orange Seal Regular put in rear tube . |
| 8/27/2020 | Continuing noise from rear is likely from crack in spoke hole. |
| 9/15/2020 | Swapped to rebuilt wheel with DM24 rim. |
| 10/5/2020 | Swapped front disc pads with old ones with less wear. |
| 10/6/2020 | Chain jumped to outside. |
| 10/16/2020 | Swapped one rear pad with a use less worn one. |
| 10/21/2020 | Replace front & rear pads with Truckerco Sintered Metal |
| Changed rear tire to Schwalbe HS 492 47-622 tire | |
| Changed front tire to Schwalbe HS 492 47-622 tire | |
| 11/30/2020 | 9th ODO reset |
| 12/3/2020 | Kickstand came loose |
| 12/9/2020 | Applied blue loctite to kickstand screws |
| 12/9/2020 | Install Tannus armor on rear wheel with new Schwalbe inner tube. |
| 12/14/2020 | Sudden voltage drops to 40's along with battery gauge depletion on display & feel to motor & then few seconds later back to normal. Happens randomly sometimes during a ride & sometime after powering on. |
| 12/16/2020 | Broken spoke rear |
| 12/16/2020 | Noticing some clutch engagement issues may be time for a new one. |
| 12/30/2020 | Power drop issue now permanent took battery off & connectors are melted. |
