FlatSix911
- USA
- City
- Silicon Valley
The same rim is used for both Presta and Schrader valves before lacing.Given how wheel rims are made, I can't possibly see how drilling out a bigger hole in the rim would be a good idea.
I did "carfully" read your posts and came to the conclusion that you just don't know what yer talking about. Not surprising as you don't own either product. To help you along, the tire inserts do fit inside the standard rubber compound tire (please see my pictures posted earlier to help you visualize this) and do most certainly require a tube. If you are referring to their tubeless tires, you need to refer to them as Airless Tires. Two different animals altogether. As I've reported earlier, the T/A foam tire liners do not feel smooshy, do not develop flat spots nor do they feel wobbly; this info gained from several thousand miles of me pedaling atop them. Take what I write with a grain of salt as equally as you do for the rider here who reported back a wobbly feel on his bike. For the benefit of everyone on the forum here, buy a couple of those airless tires, put a few thousand miles on them, then report back with your findings. Parroting other's findings as you did does not count, LOL.If you are insuieting my post about flat spots and smooshy feel as a wives tale,... I would advise to carfully read posts,.. as mine was in regards to "solid foam inserts" solid foam means NO inner tube,.. not T/A's. Reading is fundamental.
Sure, but drilling a hole twice isn't likely to improve things.The same rim is used for both Presta and Schrader valves before lacing.![]()
If 2.6" is "skinny"....presta valves are more common on skinnier rims.
"If you are referring to their tubeless tires, you need to refer to them as Airless Tires"I did "carfully" read your posts and came to the conclusion that you just don't know what yer talking about. Not surprising as you don't own either product. To help you along, the tire inserts do fit inside the standard rubber compound tire (please see my pictures posted earlier to help you visualize this) and do most certainly require a tube. If you are referring to their tubeless tires, you need to refer to them as Airless Tires. Two different animals altogether. As I've reported earlier, the T/A foam tire liners do not feel smooshy, do not develop flat spots nor do they feel wobbly; this info gained from several thousand miles of me pedaling atop them. Take what I write with a grain of salt as equally as you do for the rider here who reported back a wobbly feel on his bike. For the benefit of everyone on the forum here, buy a couple of those airless tires, put a few thousand miles on them, then report back with your findings. Parroting other's findings as you did does not count, LOL.
And when ripping a person on a forum, always but always use spell check. It just defeats the purpose and it's bad form when you don't; amirite?
It is for me.... i have a belt drive!True enuff Stefan, but then a rear tire on a mid-drive isn´t remotely as much of a hassle as a rear hub. A dbl. leg is also handy for things
like brake adjustment or spoke tuning & replacement, but I also have a rear mount single for general use on the bike. A dbl leg
requires a level surface.
With much practice, I´ve developed a tire drill for rear hubs, but it´s still annoying as hell. Too many blackberries & wild roses here whoseIt is for me.... i have a belt drive!![]()
lol
I´ve become vigilant about debris in the road, spooks the hell outa passing drivers when I swerve to avoid branches.Any wee thing that helps is a good thing when it comes to changing tyres or punctures. I'm hoping i don't get any but we'll see. Scotland has a ton of thorny trees, it's just your luck if you "get one" or not.![]()
National flower is a thorn thistle, IIRC...Any wee thing that helps is a good thing when it comes to changing tyres or punctures. I'm hoping i don't get any but we'll see. Scotland has a ton of thorny trees, it's just your luck if you "get one" or not.![]()
Hi John, care to share your method with other EBR members? ThanksWith much practice, I´ve developed a tire drill for rear hubs, but it´s still annoying as hell. Too many blackberries & wild roses here whose
thorns wind up in the bike lane. At least I´ve discovered a way to replace spokes without taking the wheel off.
Have done so several times in earlier posts , but hereś the gist. For a spoke use a tire lever to pull tire & *tube aside next to broke spoke.Hi John, care to share your method with other EBR members? Thanks
Yes, it is buddy. Those are kinda soft flowery thorns more than tree/branch thorns. They hurt like hell if you get one in your hand or whatever but for a bike tyre it is no problem.National flower is a thorn thistle, IIRC...
They story that I was told was that whichever tribe (Saxons perhaps ?) that was attempting to attack the Scots traveled barefoot over the moors and the thistles torn their feet up so badly that they weren't fit to fight, giving the Scots an easy victory. Perhaps true, but nonetheless no other country is as famous for thorns as Scotland . And I saw the blackthorn hedges in the countryside years ago on a trip. Nasty, living barb wire ...Yes, it is buddy. Those are kinda soft flowery thorns more than tree/branch thorns. They hurt like hell if you get one in your hand or whatever but for a bike tyre it is no problem.
The farmers here use these real tough tightly woven hedge things to protect their fences. They build the fence then plant these things along the line and they wrap around the fence as they grow forming a formidable divider between fields, roads and anything else. Most farmers use them here in Scotland They are evil! Those things produce thorns that will easily have the best of a bike tyre all day long! They are along some of the trails and stuff too. You wanna stay away from them buggers.![]()
Yes, Slime works well and seals larger punctures with bits of recycled tire particles in the mix.So for those who don't work at an LBS... Slime is okay right?
