I took my Vado 4 into my LBS this morning. After 2500 miles I had worn out the brake pads. They were very cool and replaced them on the spot while I waited. I had them check the chain too. It was just on the cusp of being too long, so I asked them to replace it. Again, they did right then, which was awesome. The cassette doesn't skip at all, but the front chain ring makes noise with the new chain. They had a 38 tooth narrow/wide chain ring in stock, that was the right size, but not a 40 tooth. Then things got complicated as they can't find another, even through Specialized. It's the weekend, so they'll call Specialized on Monday.
I've got two questions.
Do you think switching down to 38 teeth from 40 will be that noticeable? That switch out can happen immediately since it's in stock.
Second, since I've got to switch out the front chain ring and order a new one, should I pick another number of teeth? I have't been able to figure out why the Vado 3 & 4 have a 40 tooth front chain ring, but the Vado 5 has a 48 tooth chain ring? All three models have the same gearing on the cassette. The LBS said that if I want to switch things up, now's the time. But I'm torn about advantages/disadvantages and what to do, so I turn to my cyber buddies on this forum to help me decide the best path forward!
What would you do?
Thanks in advance!!
What would you do?
Thanks in advance!!
