Went out riding today so far NOT so good. Was going up a steep hill and I geared down ahead of time, got on the throttle just as I got to the very top of the hill it fucking wheelied and I fell on my ass. Almost did it a second time on another very steep hill that normally with my rear hub I hit it with some speed and momentum carries me. This kind of struggled at the top thought I was going to fall on my ass again.
First time to come to a stop light on this, geared down and normally on my rear hub just as I take off I start gearing up and get out of traffic. I can take off quicker than a car on my rear hub. With this I started to gear up and yep paused in the middle of a major intersection with a car coming at me wanting to make a left.
So I'm thinking why should I even change gears at all? Why not just keep it in the highest gear and just stay on the throttle? That way when I'm taking off from a stop I don't have to change gears and just let it pick up speed? Or really why even pedal on this thing? There's no middle ground with this thing, it's either balls to the wall wheelie or not enough assist and you have to continously stay on the throttle. Otherwise whenever I let go of the throttle there's a significant drop in speed. There's no coasting or cruising on this thing unless you stay on the throttle.
Then when I got down to 20% battery a couple minutes later I dropped to 0% all of a sudden so the display reading isn't even accurate. On my rear hub it has bars and if I'm down to 2 or 3 bars it doesn't just all of a sudden go to 0. It's really accurate and I've never ran out of power on the road in 1.5 yrs as my only form of transportation.
With my rear hub I can go UPHILL at 28-30 mph if I give it my full power pedaling and coming at it with momentum, I am in decent shape.  this damn thing I can't I keep pausing going up hill the only thing I can do is just stay on the throttle. There are hills every where in Colorado I always thought thy said mid drive was better for hills. It's definately not for me. On my rear hub I only use the throttle when I take off from a dead stop otherwise I just rely on assist even going up hill. On this thing I have to stay on the throttle continously it sucks.
I'd rather be able to always consistently stay in the upper 20s lower 30 mph range like with my rear hub. I can't keep a consistent speed with this thing it's like there's no assist. It's either having to put in too much effort or its balls to the wall 35-38 mph. Id rather have a consistent speed my entire ride instead of being too slow or too fast.
