Hopefully ride this weekend. Yesterday was full body CT with radioactive isotope and I got lucky today when I called for an appointment for cortisone in SI joint. Have an appointment for tomorrow afternoon.Awesome, and pics when you get a chance! Good luck with diag etc.
Good on ya, do the right thing. All my mojo sent in your direction.Hopefully ride this weekend. Yesterday was full body CT with radioactive isotope and I got lucky today when I called for an appointment for cortisone in SI joint. Have an appointment for tomorrow afternoon.
I'll be extremely happy (massive understatement) if the treatment works, as I went through this in 2015 in the UK and it was horrible. I'm pretty sure I could ride with no new damage, but a couple of extra days is no hardship.
So I finally got back on the bike and tried the new rack assembly. Initial impressions were pretty bang on - very slick product. I rode about 30kms, with only stuff in the main compartment. My first learnings is it is a significantly higher step over and my hips, especially right now, don't like it. That's OK as it was not dissimilar to my experience with my other bike. A simple solution is to just lean the bike over more.
Second learning is to avoid any significant bumps if you can. This is especially important with the side frames. Bumping around tends to have the whole assembly move a bit and can get off centre easily. I did not have my velcro strap solution installed as I wanted to see if it was needed. Next ride I will install them and see if I notice a difference. Unfortunately, I'd forgotten to bring them. Also, I don't think the interaction with the suspension seat post was any problem.
I did not notice any difference in handling nor did I notice the weight. I am guessing that I had around 3.5 Kg in the bag (8lbs). All in all, pretty pleased with the purchase and it's function. Won't be used on "dirt days", but pathway days will be better with this on, especially when there are beverage stops as the trunk bag gives me a place to take a lock or three.
View attachment 64843 View attachment 64844
Looks awesome! Glad you're back in the saddle.So I finally got back on the bike and tried the new rack assembly. Initial impressions were pretty bang on - very slick product. I rode about 30kms, with only stuff in the main compartment.
My first learnings is it is a significantly higher step over and my hips, especially right now, don't like it. That's OK as it was not dissimilar to my experience with my other bike. Simple solution is to just lean the bike over more.
Second learning is to avoid any significant bumps if you can. This is especially important with the side frames. Bumping around tends to have the whole assembly move a bit and can get off centre easily. I did not have my velcro strap solution installed as I wanted to see if it was needed. Next ride I will install them and see if I notice a difference. Unfortunately I'd forgotten to bring them. Also, I don't think the interaction with the suspension seat post was any problem.
Don't make me laugh... If they wrote DHL, that would probably work.US First Class International Mail
Was considering something like that, but adjusted my mounting today and it was much better. At the end of a 50 km ride I had to stop at Safeways to pick up some steak and a few other things. I think it took me longer to secure my bike than it did to do the actual shopping! Today's ride included some minor single track along the Bow River, and the rack stayed put better than yesterday. I'm still going to have to decide what type of ride it will be before I go out. If off pathways with no security concerns, then the seat bag. If MUP and beverage stops, then the beam rack with trunk bag full of locks.Try a metal band clamp with a turnbuckle spacer to resist compression... problem solved.![]()
