Papparay
I was unfortunate to have a puncture yesterday on my fairly new NCM Moscow + whilst cycling along a canal towpath. I thought no problem as I carrying a spare inner tube, tools and a repair kit.
Snag number one! I could not remove the rear wheel, it was jammed on tight. Another cyclist came to my aid and it still wouldn't budge. So I removed the tube with the wheel on to fix the puncture. Snag number two, I couldn't hear the leak. Water needed! And even though I had a canal full of the stuff at the side of me, I didn't fancy dunking the whole bike into it. Luckily a little old lady spotted my plight and brought me a tub of water out from her cottage. 2 punctures found and repaired and tyre put back on.
Snag number 3. I should have loosened the display and turned it so it didn't get scratched (as someone previously advised).
And what have I gained from this experience : If your bike is new, make sure you can remove the wheels before setting off on a long ride. It took a clout with a mallet to remove mine once I got back home
(1st time removal). Secondly make sure you cover the handlebars with something before turning the bike over, or loosen the display. Thirdly make sure you have all the tools to fix whatever the problem is. And lastly check your google maps to ensure you go the correct way back home. I added an extra 10 miles by going the wrong way.
Happy Days
Happy Days
