6zfshdb
- USA
- City
- Northeast Pennsylvania
Any thoughts here on the Satiator chargers? Are they worth using?
The Satiator is an excellent product although a bit pricey. There have been many posts on the product if you do a search. I own one but find myself using the OEM charger on a simple timer most of the time. It's fairly easy to estimate the charge time to get the % charge I want.
I would use the Satiator more but it doesn't play well with the BMS in my battery. Whenever I connect it, I get a message that says to "connect a battery" even though it is already connected. I have to discharge the battery slightly or connect the OEM charger first to get the Satiator to recognize it. Once I do this, the charger works fine. It's a pain though, so I wind up using the OEM charger instead.
Keep in mind, the problem is with my battery, not the Satiator. I'm not knocking the product in any way.
