Selling my Trek since I have not been able to ride to work like I expected. Purchased in April 2020 from LBS and then our office closed. Not expecting to return until Q1 2021 at this point. All stock and I will have it serviced before pick up. Medium size should fit a rider between 5'5" and 5'10".
| Frameset: OCLV Carbon, Removable Integrated Battery, Range Boost compatible, Motor Armor, internal cable routing, post-mount disc, 12mm thru axle |
| Fork: Allant Carbon fork, post mount disc, 100x15mm thru-axle |
| Front Hub: Shimano Deore XT M8110, centerlock disc, 15mm thru-axle |
| Rear Hub: Shimano Deore XT, 32h, centerlock disc, 12mm thru-axle |
| Wheelset: Alex MD35, Tubeless Ready, 32-hole, 35mm width, presta valve |
| Motor: Bosch Performance Speed, 75 Nm, 28 mph / 45 kph | ||||||
| Shifter: Shimano XT M8100, 12 speed | ||||||
| Rear Derailleur: Shimano XT M8120, long cage, Shadow Plus design | ||||||
| Crank: ProWheel alloy, 170mm | ||||||
| Cassette: Shimano SLX M7100, 10-45T, 12 speed | ||||||
| Chain: Shimano SLX M7100, 12 speed | ||||||
| Saddle: Bontrager Commuter Comp | ||||||
