Ebiker33
I see this is a option now on the Watt Wagon, since it's more money than the Rohloff, is it worth the upgrade, is it really better?
Anybody have this and tested it ?
https://kindernay.com/products/
"They work quite well, need minimal maintenance, and we have not had failures in our tests even with with full unrestricted throttle."
Being able to throttle with the full 160nm of the Ultra is a great upgrade, I really like it.
- 543% gear ratio with 14 speeds in sequence, and even 13.9% intervals
- Lightest 14 speed gear hub ever, approx. 100 grams pr. speed
- The first multispeed gear hub with a full-length tunnel extending all the way through, for receiving standard 12 and 10mm through-axles
- Multiple axle stub versions available, for both 142mm/148mm/197mm x12mm and 135mm/190mm x10mm frames
- Rigid axle mount with minimal torsional flexing, for a stiff rear wheel
- 24 engagement points per revolution, for rapid pedal engagement at any time
- Large diameter clutches, for high torque-capability and gear strength
- Instantaneously shifts – once the shift-click is heard, the shift has been completed
- Shift standing still, shift coasting, shift while airborne, shift under load
- Low maintenance, very long service life
- Outlasts your bike – move it on to your next bike, or sell it and upgrade to a next-gen version
