Zeek48
YesWas your bike acting the same as mine with the pink light only on and blinking when the ext. battery was on?
Karl, when you load the app and connect to the bike you will see an error code with an explanation. Someone else in one of the other threads had a similar problem. Check it out. It was a bad cell in the auxiliary battery.Was your bike acting the same as mine with the pink light only on and blinking when the ext. battery was on?
In order to see the error code in the app, you must touch the red exclamation mark which should then show the error code at the top of the screen for a moment. You can then take a screen shot with your phone.Hi All, I received my Orbea Gain D50 yesterday, went out for a test ride and everything worked fine. I've put the bike on charger for 3-4 hours last night and when I disconnected, switched on and I had the dreaded pink light flashing. No error code in my app, only the red exclamation mark. I tried to disconnect the motor and switch the bike on and then I had the correct error code in the app. I have tried switch on and off several time, but still not working and pink light flashing. Anyone has any idea what is the problem?
Not sure, but I think you are referring to my post. It was not a flashing pink light, it was a flashing purple light. Sent the error code to Orbea and they have agreed to replacing my external range extender battery. Hoping the new battery rectifies the issue. I have had to stopped using my current external range extender battery.Karl, when you load the app and connect to the bike you will see an error code with an explanation. Someone else in one of the other threads had a similar problem. Check it out. It was a bad cell in the auxiliary battery.
Pink, purple, I think it's the same thing.Not sure, but I think you are referring to my post. It was not a flashing pink light, it was a flashing purple light. Sent the error code to Orbea and they have agreed to replacing my external range extender battery. Hoping the new battery rectifies the issue. I have had to stopped using my current external range extender battery.
				See my video at -Hi I have a new Gain D30 and have used it twice. On both rides a clicking/clanging noise while pedaling happened. Does not seem to be the chain. Could be the hub. Here is a link to a short video with the noise. Gain hub noise. Any ideas? Have brought to dealer and they are looking at it.
I tried to include a short video of mine ... link did not work? My noise sound more like a spoke noise ... it almost rings vs clunks and happens when I’m pedaling with or without actually applying pressure. If it is the hub I kind of want Orbea to send the dealer a new wheel. This bike is less than a week old and was imported directly from the factory in Spain when I ordered it from the dealer (how they are doing US sales now).See my video at -Is this the same noise you are having?
I sent the rear wheel back to the selling dealer and they replaced the free hub but they said what they thought was the issue was after removing the cassette there are 3 screws on the hub that were loose and hitting the cassette. After the repairs it stopped making the noise. Mine only made the noise when coasting.
I was able to watch your video. Sorry I was not able to be of help.I tried to include a short video of mine ... link did not work? My noise sound more like a spoke noise ... it almost rings vs clunks and happens when I’m pedaling with or without actually applying pressure. If it is the hub I kind of want Orbea to send the dealer a new wheel. This bike is less than a week old and was imported directly from the factory in Spain when I ordered it from the dealer (how they are doing US sales now).
I’m glad they were able to fix yours and I appreciate your comment. I’ll mention to the LBS that maybe they should open the hub and look at it, which led to your solution.I was able to watch your video. Sorry I was not able to be of help.
Hi, for what it's worth the bike shop fix (to add spoke prep or spoke freeze which may be something akin to glue) worked for me ... did a 34 mile ride yesterday without the noise. I have not noticed added drag from the drivetrain and am very happy with the bike (but I also need to be ... this was no small expense for me). Sorry that your experience has been different. Good luck!I have the same problem as Pete D with my 2018 Orbea Gain D10 with 1100 miles of use. I have never been 100% happy with the bike because when I was looking at the reviews and marketing blurb before I made the purchase I was under the impression that the system was zero drag and despite what a few people on this forum and others claim there definitely is drag. For me, I wanted a bike that I could ride like a normal bike for 75% of the time. I can handle the extra weight, my old mountain bike is even heavier and I never had a problem taking it on fairly long rides in the past. All I need is the motor to assist on the steeper hills, cycling with headwinds and to ease my hip and knee pain if they are playing up more than usual on any given day but now with the additional worry of this new noise I'm wondering is it safe to ride and will it pack up mid-ride? This is so close to being a perfect bike for me but just misses the mark. Has anyone ridden a Fazua powered bike as well as their Gain? I only have a Halfords locally that have Fazua bikes for a test ride but I don't really like doing that as I would have no intention of buying from them. Any thoughts or opinions would be appreciated as I think it might be time for me and my Gain to go separate ways sadly!
				 www.youtube.com
					www.youtube.com
				Hi Adrian - I can't help you but I can tell you that I have had exactly the same experience with my 2017 Gain D30 today. It's dead when unplugged and won't turn on. When plugged in to charger seems normal but just sits at 90%.Hi. I have recently purchased an Orbea Gain F20 and have a problem with it - would be grateful for any help. It has been working perfectly up until this morning - when I tried to turn it on it was dead. Plugged it in in case the battery was flat, and it came to life - the app says it is at 90% charge, and it works as expected when plugged in. As soon as I unplug it it goes dead again. If I leave it plugged in it flashes white for a minute or so, then solid white, and the app continues to say 90% charged. Has anyone experienced anything similar? Thanks for your help.
