Last year, I was riding my Juiced Ripcurrent S Fat ebike in the Green Mountains and quickly found out that my front Star Union 150PYD brake is simply not adequate for the type of riding I am doing. I do weigh in at about 240lbs, and when my RCS is fully loaded, it's up over 250. Even bleeding, adjusting and trying high quality ceramic and semi-metallic pads wasn't much help with the Star Union when going 50mph. Due to this, I need to find a better front brake system. After doing a ton of research, I just ordered the Magura MT5e with aluminum lever, a Magura 180mm MDR-C 2mm thick rotor and the Magura QM-40 mounting adaptor that mates the caliper to my MOZO Fatman air spring front fork.
Once narrowed down to Magura, I got some help from Jude over at Magura to find the correct parts for my bike. He was also kind enough to shorten the hydraulic line down to 33-1/4" for me so I didn't have to do it.
Now the big questions... Will this behemoth fit??? And does anyone have any experience installing a MT5e onto a Ripcurrent S or any experience just with Magura products in general? I know they make excellent motorcycle brakes, but that's from an entriely different industry with different demands.
UPDATE approximately May 20, 2020- So, does it fit???
YUP! It fits just fine. Install was pretty easy. There is some pad rubbing at first, but I broke-in the gray double 9.P performance brake pads by doing several hard slow-downs while going down hill. The MT5e modulates quite nicely with my 2-piston rear Star Union hydraulic brakes. This is a gi-normous improvement over the Star Union front brake.
