Yes. I believe they call NO "Closer" (it's a German company, so their translation is a little weird)Good! And is it necessary to say I want one NO brake lever when I order?
Are you getting just front or both front and rear?Good! and is it necessary to say I want one NO brake lever when I order?
You need to order one front "closer" and one rear "closer". Are you getting the MT5e or some other model?I intend to have front and rear.
If you're getting them direct from Magura, they're out of stock right now. I had to wait to get mine from them, but it was during the winter. Other bike shops carry them, but you need to be real careful when ordering.I think the MT5e is the one I will go for.
Was only like 2 weeks. This is what I got for my front only;Yes, thanks. Did you wait a long time?
I think so, but you'll need to buy 2 Magura adaptors for the front and rear no matter what size rotor you use. Magura can tell you which adaptors you will need for your bike and the rotors you choose. I sent them pics of my bike and they knew which adaptor to send.Hey, I need to know if I can use one rotor 180 or 203 if the manufacturer of my frame tells 160?
I kept the stock Star Union dual piston. It's not nearly as good as the Magura in front, but I feel it modulates well enough between the two.Hey, if I may ask, what have you for your rear?
Well, I'm no expert, but I'd say going with an undersized disc defeats the purpose. The 4-piston MT5e works best with the Magura 180-203mm disc.ah good. Do you think that's possible technically to use discs 160mm with eMT5?
We'll talk againthanks!
Yes, like you said!
Are you sure that the magura lever Higo red is one 3 pins connector?
Because I don't understand why it's not a yellow Higo? This one is 3 pins.
