RESTLESSSWIND
It seems that I can't get a smooth indexing sequence on my 2020 Vado 3.0
It started when I only had a couple hundred miles. I shifted from 9 to 8 under fully assisted load at a very slow speed. Busted the 11 tooth cog on the low end shimano cassette. I replaced the cassette with a Deore 9 speed. Everything seemed fine, but the 8 to 9 shift seemed to not shift smoothly. Would always stick until I back and forth pedaled. No big deal. Fast forward to 3000 miles. I decided it was time for a new chain. I put in a KMC x9 . I am having a heck of a time with indexing. I changed out the jockey wheels and bought a SRAM cassette. Things are a little bit better, but I think the deraileur is wearing out already (Aliveo). It seems to look like new still, but I think the outward tension of the mechanism is getting "soft". I'm not so sure I want a mid drive again with a derailleur. Seems too much torque on the rear axle transmission. Thoughts? Ideas? Should I be replacing cassette and derailleur every 3000 miles? Shifter and cable movement seems to be fine. It was indexing fine until I changed the chain. Hmmm....
