Good grief, some of the information passed on. Most of it is good, alot misinformed!
Scramjett: I'm the owner of two fatbikes. The first, a Specialized Fatboy. Hard tail, no suspension save for the Cane Creek Thudbuster LT I installed. 4.6 inch wide tires, ridden up to 20 psi on asphalt roads. I have about 4000 miles on my Fatboy; bought new.
My other bike, which has effectively knocked out further use of the Fatboy, is my Haibike Full FatSix. One of the premium fatbikes out there, with top tier components compared to that Bixtrix fatbike mentioned elsewhere. Yamaha PW drive. Fully decked out by me with front and rear racks to accomodate all kinds of Ortlieb bags for day rides or touring. Front Schmidt SON28 dyno hub powering up a front German made Schmidt Edelux II headlight and Schmidt Son rear tail light. Tubeless tires. Cane Creek Ergo bar ends on a 60mm riser bar by Spank. Ergon saddle. Abus Bordo lock.
With that out of the way, I ride this bike anywhere, anytime, any condition except water fording. As it should be with any other ebike.
The Fatboy convinced me I could ride this bike on asphalt, albeit it's gonna be averaging about 13 mph. But no bike ever made me smile as to the "feel" of the bike when starting out on every single ride.....there is simply no substitute for the feeling of control and stability on the fat tires. None.
Unlike skinnier mtb tires, my fatbikes easily go through the deep sugar sand of the New Jersey Pine Barrens. THIS is where a fatbike really shines, sugar sand and snow. It's just a matter of airing down to 6 or 8 psi and you are good to go. Done with the deep sand? Air back up and bike on!
Truth is, most of my miles accumulated on the Haibike is on asphalt roads. Last count, 9400 miles on the odometer after putting her into full time service in the late spring of 2017. Asphalt roads mean nothing with this Yamaha ebike drive. In the height of summer when I am in the best of cycling shape, I can linger at 19-20 mph at the motor cutout on a 16mph plus average speed on a 20 mile run that I typically make.
Any ideas of a fat tired ebike not good on riding asphalt roads is rubbish. This past summer, I ebiked the Full FatSix from home on the western side of NJ, to the east coast of NJ at the Atlantic Ocean, then turned around back home. Summer time, 90 degrees plus, 95 miles. All on asphalt.
A fat tired ebike can go anywhere a mtb can go....and then some. It may not be faster (who really cares about that?) or lightning twitch-quick maneuverable on some Alpine Pass (who really goes down that stuff on a forum such as this one?); but it is like a Jeep Rubicon of all bicycles, hands down. The Rock Shox front and rear suspension on the Haibike takes out the dips and crowns of the local roads I ride here in NJ. Suspension on high end bikes are nothing like the dual suspension bikes that first came out in the 1990's. They are a real game changer in rider comfort!
Some pics of the Fatboy and the Haibike Full FatSix......
Good grief is right Mike TowpathTraveler. I guess we should be thankful you straightened everyone out!![]()
Hey Mike- How are the knobbiies holding up after all of those asphalt miles? I was told they can wear down quite quickly doing those kind of surface rides. I ride on 2.8 knobbies on tarmac as well and was curious if you have had to replace them yet (the original Jumbo Jims)? Nice post!Good grief, some of the information passed on. Most of it is good, alot misinformed!
Hey Mike- How are the knobbiies holding up after all of those asphalt miles? I was told they can where down quite quickly doing those kind of surface rides. I ride on 2.8 knobbies on tarmac as well and was curious if you have had to replace them yet (the original Jumbo Jims)? Nice post!
This is good to know. I have been using stock knobbies. When they are worn, I will have to consider these options before replacement. Thanks for the heads up!I couldn't stand riding on pavement with the stock Kenda knobbies on my bike. Went to 3.5 in street tires and it made an amazing difference.
That is good point one can change tires to better suit there own personal needs. I remember reading an articial about some riders many years ago using a fat slick to ride on rock believe it or not. The "slick" part is kinda miss leading it was a sticky tire and the rock was like ledge or like a big smooth MT. top. When you said that about the tires I thinking of the old ground controls and how much drag and noise they made on the pavementI couldn't stand riding on pavement with the stock Kenda knobbies on my bike. Went to 3.5 in street tires and it made an amazing difference.
Mike-Sorry to hear your bad luck with tires.Hi Bob,
The center tread seems to take the most wear from what I've observed. Noted too, the Jumbo Jims seem to have a softer, faster wearing tire compound (Addix) compared to the Ground Control 4.6's on the Fat Boy. I used to run at 30 psi, the rated Schwalbe max tire pressure, but have since eased off that setting by operating at 25 psi for the best possible battery range.
I would estimate 2 years of use out of the tires. Since putting this Haibike on the road, I've gone through 2 rear tire blowouts, one due to running over some kind of sharp metal debris on the shoulder of the road. The second was after a tire tube blew out internally; destroying the tire bead from ever sealing again. One front tire was lost after converting over to tubeless, where upon seating the tire to the wheel, the bead let go, again, making the inner tire bead unsealable.
To replace tires due to just plain old road mileage wear is one thing, but to lose perfectly good tires under those circumstances noted, it was a pretty tough, expensive bill to swallow.
The noise these tires make on the road sure gets the attention of everybody within range.
Mike
Nice pictures, Mike!
Amazing how clean you have kept itand nice accessories too
I think poor design and geometry is amplified by fat bikes. The budget bike I bought to kit sucks. Yesterday I tried a top tier KHS and it was a very different ride. I’m wanting to try a studded tire version for ice fishing. I’m thinking it’d be perfect.Hey, no problem, Rich. Still looking forward to that tutorial of yours regards to poking about battery terminals, regardless of not knowing which terminal(s) are which! 1-2-3, it don't matter!
Now, I must be off, practicing quick steering & biking maneuvers cause as you personally know, a fat bike is poor in that department. Nor is it worth a darn going in puddles as per your personal experience...... let alone riding in "the wet" thanks to these knobbies; another poor riding trait you found in thousands of miles of riding one of these rigs. Any ideas as to how I can eliminate this "crown" in my Schwalbe Jumbo Jims? It seems you are holding back on us on how we might be able to do that. Does it involve a 5 inch reciprocating disc sander?
LOL, Rich. I just have this thing about some people (you) passing along wives tales to new comers who are just trying to seek legit advice. It's comically clear to me you don't know what you're talking about.
Did you try going to www.haibikeusa.com?Hello all,
Thanks for the feedback! Everyone has definitely given me something to think about here.
@Mike TowpathTraveler, I was looking at a Haibike for a commuter, specifically the SDURO Trekking S9.0. I went with a different bike but I may look at them for a mountain bike. Do they do direct sales? I ask because there are no Haibike dealers where I live. Also, what do you think of Bulls?
Hello all,
