I am in process of purchasing a 2019 Haibike SDURO Trekking 9.0.    I put this post under general as even though I am talking about a specific bike - this question could apply to other makes/models.
1. The bike comes with an in-tube Bosch 500 battery connected through the bottom side of the down-tube.
2. There is an option to add a second battery on top of the down-tube through their "modular rail system" (MRS).
- This is not an in-tube battery but rather the typical Bosch battery pack that sits on top of the tube.
- In this configuration, both batteries are connected at the same time.
- Of course, you do not need to have the second battery hooked up
3. I do want a second battery - so based on these assumptions...
- The cost between the two options is not significant factor in my decision
- I do not always need a second battery but need one for certain occasions (less than 20% of the time).
- I will have a backpack or trunk when I need the second battery
4. Would you go with...
a) the MRS battery option? or
b) the extra in-tube battery option (kept in a trunk/bag) to swap out when needed?
....and what pros and cons do you see with going one direction vs. the other?
Your input is much appreciated!
