How many would you like?
In fairness you are right, the actual circlip used by Bosch is like their bearings, a bespoke part! I have been searching for 6 months! And as no one would make them for me (unless I wanted 50,000 or more!) So, I have found the closest possible match. They are 0.078 (2mm) thick, then I have to give them a slight tweak and a touch on the grinder to make them identical to the original Bosch ones.
A pain to do but it's the only option available at this time.
Give me a shout through www.performancelinebearings.com and I will help you out.
Thanks for the info but it was just a curiosity. I don't need it at the moment, I was just wondering where I could find a replacement. I am currently using both FSA and Miranda crank arms and both makers told me to close the bolts to 40 Nm (not more), so I never had problems whit these circlips.
Anyway it is very strange that since they are available as NA84 here (https://www.gandini.it/www/anelliar...id=gb&idsottocat_articoli=NA&idcat_articoli=8), they should be also availabe as NAS84 here (https://www.gandini.it/www/anelliar...d=gb&idsottocat_articoli=NAS&idcat_articoli=8) but for some kind of magic NAS84 is missing...
Anyway, if I'll need a replacement I'll contact you surely.
Thanks again.
