Cameron Newland
So I've got a 2015 IZIP E3 Dash that I absolutely love, and I also own a portable solar panel that is only really useful for charging cellphones, tablets, and USB power banks, as it only gives off 0.5-2 amps at 5 volts, and only gives off more than 1 amp in strong, direct sunlight. Obviously, my portable solar panel is too weak to add meaningful power to my ebike's battery, but would it be possible to connect the solar panel to my ebike's battery using a USB-to-3-pin-XLR connector, and then trickle charge the battery a bit?
The original charger states that it needs 100-240 volts at 50 or 60hz, so using the original charger to cut off the charge at 54.6 volts (a full charge) wouldn't work.
Is it even possible to charge a 48v e-bike battery with a 5v power source?
I don't think this is going to work, but I'm just curious if it is, because at some point, someone is probably going to set up portable solar charging for their e-bike (or perhaps it's already being done!).
