I'm playing around with downshifting technique on uphills with a internal hub (Shimano Nexus Inter 7 powered by a Bosch Performance Line mid-drive motor). Wondering what approaches others have found the most efficient/effective. For instance: Sometimes I stop pedaling completely for a split second and then downshift, even in the midst of pretty steep grades. It works well enough, but obviously I lose some speed in that instant. Other times I just let up pressure a bit as I shift, just as I would with a derailleur, but the responsiveness is lower and it seems to require split second timing. The former technique seems to be most effective, but perhaps there's some middle ground, some combination of approaches, or something I'm not even aware of, that would work best. (One thing that the internal drive allows you to do is downshift over the entire range of ratios when pedaling stops.)
