Please Critique the 2019 Trek Powerfly 5 as a Practical Car Replacement Strategy
Finding a “commuter” bike with decent “cargo” capability might be an unreasonable tradeoff. Cargo and commuter bikes have different braking characteristics. Good braking requires low placement of weight. The top platform of a rear rack is too high to be the ideal location to carry weight. A rack container may also prevent you from making evasive maneuvers by moving your weight over the back wheel. I often reflexively get off my seat to shift my weight back backwards.
My car replacement adventure starts with a few steps into the foggy realm of eBike transportation. For the past two years, I rode my ordinary pedal bicycles three times the distance that I drove my car. I rode 100+ miles per week through the Denver winters. I naturally pedal between 20 to 25mph on the flats, so I prefer a pedal bike over a motorized bike, under normal conditions, loads and time constraints.
I sold my car, so the cost of a new eBike and a second battery is not an issue. I feel that only 20 to 40 days per year, e.g., 10%, are completely unrideable for me. I am willing to take a bus or taxi for the other days that are only manageable in one direction, e.g., (25%). The biggest impediments for me are midday heat, wind, daylight hours and wet surfaces.
https://www.trekbikes.com/us/en_US/...-hardtail/powerfly-5/p/23180/?colorCode=black
I reasons that favor buying the 2019 Trek Powerfly 5 are:
The reasons why I might reject the 2019 Trek Powerfly 5 are:
Carrying 30 pounds of food per trip seems reasonable. The tubeless Powerfly tires are 2.4 inches wide. I imagine the tires make a stable contact patch to balance heavy weight because the tubeless tires are ridden at low air pressure levels.
Paying Walmart $10 to deliver food once or twice per month for bulky or heavy items is necessary without a cargo bike. Making two trips per week by bike is not a problem, because I can bike to Walmart in less than ten minutes on my ordinary pedal bike.
The entire 1.5 mile return route is a consistent 2% grade. I will brake the entire way back to keep the speed under 15 mph. I coast the entire route at about 15 to 20mph on my pedal bike. I am waiting to hear back from Trek about the most appropriate brakes. I would love to hear your suggestions.
I ordered the same brakes as on the highest specified mountain bike, the Powerfly 9.7. The Shimano MT520 4-piston Kolben hydraulic disc brakes would replace the stock Shimano MT200 hydraulic disc on the PowerFly 5. I believe the rotors are 203mm?
Since I do not know how to calculate stopping power, I decided to err on the conservative side. Perhaps, these brakes are overkill and will throw me over the handlebars? I reason that I need at least two brake pads for each caliper to keep the wear and heat to a minimum. 203mm rotors dissipate heat best. My Yeti ASR-C has Shimano Deore XT hydraulic brakes with 180mm rotors. I love the brakes.
I assume the front shocks will have enough travel for stopping with a 300 pound load? Waiting to hear back from Trek. I would love to read your feedback. Details:
Some other items in the order that I appreciate feedback about are listed below:
I hope to fit 30 pounds of food into these rack containers, that seem quite small. I would love to hear what you think about the carrying capacity of these baskets and bag.
Bontrager BackRack Disc | Trek Bikes
www.trekbikes.com
Enhance your cycling experience with Bontrager BackRack Disc. Shop now for FREE shipping on orders over $49!
This pannier basket easily attaches any Electra rear rack. is: (12x12x9 in). Unsure whether it attaches to Bontrager Interchange system.
https://www.trekbikes.com/us/en_US/...-rack-pannier-basket/p/12612/?colorCode=black
Electra Steel Mesh Rear Rack Pannier Basket | Trek Bikes
www.trekbikes.com
Enhance your cycling experience with Electra Steel Mesh Rear Rack Pannier Basket.
- The battery in enclosed in the frame, which offers some protection from the elements.
- The hardtail is the only option that allows for a full rack, which allows me to carry a second battery above the wheel.
- The 12mm rear axle allows a Burley trailer to be attached.
- The rims have a 40mm inner width, that allows for 2.4 inch tires
- The brakes can be upgraded to dual brake pads, for adequate stopping power with 300 pounds total weight, including cargo.
- The Nyon display allows me to manually configure battery power for different assist levels.
- The Nyon displays battery usage as a percent, to maximize battery life by never falling below a 40% charge.
- The kickstand supports up to 250 pounds of weight to load cargo onto the bike.
- I could adapt the Trek Bontrager Interchange base plate to support a cargo box on the rack.
- The rims are tubeless.
- Fender attachement bosses
- Walk mode is disabled by Trek, which makes the bike dangerous for crossing busy intersections when it weighs 100 pounds with cargo. This thought actually frightens me.
- The 100mm front fork travel may not be adequate for abrupt stops at 300 pounds.
- I might not find a cargo bike with a compatible 500wH Bosch Powerpack battery.
- The total weight limit for the bike is 300 pounds. I have not gotten an exact explanation for the weight limit, but I can only imagine the limit is related to stopping distance at 20mph for 300 pounds.
- At a lean 210 pounds, the 55 pound bike might be impractical for me, with a 300 pound weight limit.
- The maximum cargo capacity may be inconvenient for weekly perishable food shopping.
- Bosch has production ABS brakes for eBikes, which might be worth waiting a few months for.
- Evidently, the light wires cannot be internally integrated?
- No upgrade available for 15 tooth ring, apparently.
- Braking for heavy cargo necessitates the weight be distributed low over the rear wheel, rather than high over the rear rack.
- RockShox Judy Silver TK, Solo Air, rebound adjust,
- TurnKey hydraulic lockout, tapered steerer,
- G2 Geometry w/51mm offset, Boost110, 100mm travel
- Nyon display to manually optimize battery power levels and battery life for different modes.
- A second battery for longer distance and redundancy in case of failure.
- Kickstand
- The same light as on the Super Commuter+ 8
- Integrated Supernova M99 Pure+ Headlight (1,000 Lumen, Light Sensor Mode Control),
- Integrated Supernova E3 3-LED Backlight
- The tubeless tire most similar to Schwalbe Super Moto-X, 27.5x2.4˝. Waiting to hear back from Trek.
www.trekbikes.com
www.trekbikes.com
