Trail Cruiser
I did not realize that 16 percent grade could feel this steep.
I was able to clear the hill but barely, in first gear, and standing up on the pedals, with rear wheel scratching the road surface. However, I also used the lowest level of assist since I did not want to fry the motor of my Magnum Metro+.
In my Giant MTB retrofitted with BBSHD, I did not have to stand up and it had no problem tackling the grade. However, I was using the second highest level of assist (programmed at 600 watts on my controller). In mid drives you can confidently use more power at the hill as long as your cadence is high (motor spinning fast).
