I accidentally posted this in another thread....I meant to post it here.
I ended up buying this battery and tested it.
So the test results are in........
I used a 48v inverter and measured the results with a reasonably accurate MNJ MOTOR DC Multi function Battery Monitor Meter with 100Amp shunt
The load was 16.1Amps total and consisted of a small heater and an air purifier.
Ambient room temperature was 75F and relative humidity 38%. The battery started at room temp of 75F for this test.
Here is the inverter with battery next to it
And here are the results.......
The final Amps was due of course to voltage drop as the battery voltage drops, current rises proportionately
So I got 18.5Ah at a discharge rate of 16 amps
The battery is billed as 48v 20Ah.
But as you may know, manufacturers are pretty much free to rate their batteries as they please.
I found that if I discharge this battery pack at 1amp it does indeed yield 20Ah. But you cannot operate any ebike on 1amp.
So I assume their rating scale is based on a discharge rate of 1amp or 0.05C
Walmart Lead Acid batteries are rated at a 122hour rate so as I said, ratings are all over the place and don't mean much in and of themselves.
The question becomes......is this amount of capacity at 48v worth $320.00 ?
I'm not sure how many people actually run a quality capacity test on their battery so this may not be readily available information.
But I suspect it's very much par for the course and that extra 1.5Ah would cost a pretty good premium.
I priced out good 18650 cells that would give me 20Ah at 48v and I think it came out to about the same, but I'd still have to buy a BMS.
18650 cells do not have anywhere near the cycle life of a LiFePO4. Roughly 500 cycles for the 18650's and several thousand for the LiFePO4 pack depending on care and use.
I hope this information is beneficial to someone.
https://www.ebay.com/itm/262991429972?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160727114228&meid=acec816e9b564d548eae6c5dba000905&pid=100290&rk=1&rkt=4&sd=262991429972&itm=262991429972&pmt=1&noa=1&pg=2506613&_trksid=p2506613.c100290.m3507
48V20AH LiFePO4 Battery Power Pack for Scooter Ebike Rechargeable Motorcycle
