Would a left chain drive help me?
Hub drives are at an inherent disadvantage in hills. Period. There is no gearing pitfall.
You're out of your mind. At 260 rpm (20 mph on 26" wheels) a geared hub drive rotor is only going 1300 rpm. 10000 rpm is not a problem for electric motors. As for the controller that uses mosfets, audio amps that use similar mosfets can reproduce 20000 hz at full power.
As for your fixed gear test run, humans can pedal maybe 150 rpm? At my age 80 rpm is a stretch. Totally different situation. Reason 99.999% of pedal pusher bikes sold have speed multiplication only; no torque multiplication.
Come ride 80 hills with me. You're not allowed to change the chain for 2 1/2 years. With a mid-drive you' be walking at the end of my 5000 miles.
What an ironic choice of words! It's obvious that you're not listening and have made up your mind. I just hope your misunderstanding of drive train technology doesn't mislead other readers into making bad purchases.
I think it is funny to see a belt to a hub-drive.
The motor on the back of that bike doesn't look 12" in diameter. If it whines when you push it backwards, but makes no sound when you push it forwards, then it does have internal gears. If it doesn't, gearless hub drives are fairly useless for climbing steep hills. The torque doesn't reach rating until about 100 rpm. The geared ones are useful. The rotor inside runs 5 times faster than the bike wheel. Torque is much higher at low speeds.
All the mid drive mania above glosses over a huge pitfall. Unless the sprocket on the back wheel is bigger than the one inside the mid-drive, it does not have torque multiplication. Only speed multiplication. As you notice, bikes with 48 or 50 tooth rear sprockets cost mid $$$$. Or LLLL in your case. I couldn't even find a 32 tooth 7 speed freewheel to fit my rear hub drive. In the catalog, never in stock. 28 teeth wouldn't get me up the hill when the rain took out my throttle, even with a 32 tooth front sprocket.
What mid drives do better than geared hub drives, is climb 1000' in an hour without overheating and shorting the windings. There is not a 1000' hill in the UK IMHO.
You may be able to use the same frame controller & battery, but buy a power wheel (with the same connectors) that is geared. I'll wager a Mac12t geared hub motor will climb your hill with a 25 A controller, if you plus bike weighs less than 150 kilos. https://www.alibaba.com/product-detail/Mac-bldc-hub-motor-6T-8T_60512780782.html I'll not wager that UK customs won't confiscate either at the port or airport. Its still legal to buy these things in the US, but not to ride them on road in about 48 states. Mine had a top speed of ~23 mph on 48 v (54.6 max) but the deadly 750 w limit means its not a bicycle motor under the 3 class system. Domestic retaillers have stopped selling them here. What mine would do is start 150 kg me+bike+groceries up a 15% grade, and accelerate to about 9 mph uphill, without help. Retired bIke riders riding 9 mph uphill: we may as well be displaying Uzis!
I don't know how high UK hills are, but your comment reminds me of a movie--"The Man Who Went Up a Hill but Came Down a Mountain." No great message there, but an amusing flick.
The 6001 bearing in bike motors (I've had 3 apart) is the same type used in 42" riding lawnmower quills. In mower service they rotate 3000 rpm and conduct ~6 horsepower to the blade for a couple of thousand hours. At least the Argentine ones used on lawnmower quills do. The ****ese bearings used in ebikes probably aren't real alloy steel but I replaced one; the BNC's fit.
240 rpm and 1000 watts is nothing for a 6001 bearing.
