spokewrench
- USA
In February, my Aventon Abound began making a brushing or scraping noise each time the right pedal passed 5 o'clock, approaching bottom dead center. Eliminating external rubbing, the pedal, and my shoe, I decided it was the right BB bearing, which handles both the pedal load and the chain wheel load, which is 75% higher. I thought it was a bad bearing until I realized it happened only when the metal was below 60 F. It seemed that the cold lube was too stiff to keep the whole race covered.
There hadn't been a problem in December and January, so I thought the lube had thickened. I bought squeeze bottle of Liberty synthetic oil, which has an 18 gauge needle, intending to inject oil through the rubber seal in order to thin the lube. After it arrived, I thought of something else. If I used the throttle to get underway on my driveway, I could pedal around with no bearing noise even with the BB at 40 F.
I'd bought my first ebike in 2020 and added another in 2022. They were one-speeds, so I always used throttle to get going. The Abound arrived about December 1. I used PAS to get underway because I had trouble seeing what gear I was in. It took until January to get a cable long enough to replace the shifter. I guess in January I continued to get underway with the motor much of the time, out of habit.
I prefer using pedal power alone because it's silent. A cyclist accelerates as fast as possible up to 5 mph or so, where the steering response is fast enough to stay up. That requires maximum pedal pressure, and in a given gear, peak pressure lasts 10 times longer at 1 mph than at 10 mph. One way of looking at viscosity is that it's how much oil resists being squished from between bearing surfaces. High and slow peak loads could leave little lube in the section of the race that bore the load. In cold weather, the lube might be too slow to seep back in.
Low gear on a traditional English bike was about 53 gear inches, which I think may correspond to 5th gear on my Abound, but getting underway at any temperature didn't cause bearing noise. It seems the Abound wasn't designed to ride without motor assistance. What about other ebikes? Do other riders like to get underway without motor assistance?
