spokewrench
- USA
After 150 miles on my Aventon Abound, I started hearing a brushing sound when the right pedal passed bottom dead center. I imagined maybe there was runout on one of the chain wheel guard wheels and it was brushing something at that point. I removed the chain guard and found a pin oak leaf at the bottom bracket. That's what it sounded like. The guard wheels didn't come suspiciously close to the chain guard or anything else.
Removing the leaf didn't stop the noise. I removed the chain guard for further study. Nothing. Besides, if something was rubbing, I would have been able to hear it turning the crank by hand. The pedals turned smoothly on their spindles but with a lot of resistance as the lube were viscous like cosmoline. I thought it might be a creak in my shoe. Changing shoes didn't help.
In fact, it's silent when I set out. On a test, I went 500 feet up the street. The hardest pedaling was when I set out, climbing a 2% grade while getting up speed without shifting down. Then over the rise, down a 2-to-4% grade, and a u-turn, all silent. Then the brushing noise started, up the grade, over the top, and down the grade to my driveway. I think it has something to do with the thick lube: a bit of hard pedaling squishes it away from where it's needed.
I swapped the new metal pedal with the plastic right pedal from a Radmission, is service 16 months. The plastic one spins with no lubricant drag. It was too dark and cold to test immediately, but I assume now the Radmission will have the brushing noise.
I've never taken an old pedal apart to clean and lube, much less a new one. With maybe 26 eighth-inch ball bearings, it sounds like a headache. Does anyone do that to inexpensive pedals? Are there other pedals with lots of lube drag?
