What To Look Out For In Buying A Pre-owned Stunner X
Cirque
Nubie here. I am looking at getting into the ebike scene. I'm looking at a Biktrix X. The seller has replaced only the chain and the bike has 1,300 miles. What should I look at closely before purchasing this bike?
Thanks.
Brake pads are probably due to be replaced, but that’s an easy cheap job. Tires are getting close to life by mileage, but it depends on how the bike was ridden.Check cassette for chipped teeth.
The biggest liability is the battery, 1500 miles is fine. The bike was ridden which is good, bikes not ridden with battery discharged are a problem. Check the fully charged voltage, the bafang lcd displays usually have a setting for that. Should be around 53 volts for a 48 volt battery.
Other than that ride it and listen for noises. Used bike prices are still high as many new bikes are unavailable, it’s summer and people want to 🚴 NOW.
