MrCaspan
So I am a complete Neb when it comes to this stuff but really pick stuff up quick. I wanted to get a few simple question answered..
1. Can any battery work with any controller as long as it's rated for it? IE you can use 48v with a controller that can take 48v or a controller that can do 20v to 70v?
2. Do you HAVE to pair the screen to the controller or the other way around? Should I pick a screen then find a controller that's compatible with it?
3. When choosing my wattage ratting of my controller should my controller be rater lower then my motor or higher then my motor. I know motor rating ie 500w is normally it's running wattage not its peak wattage. So I am thinking my controller should be rated over my hub motor so it can provide the peak power it needs when on hills etc?
4. when pairing a hub motor to a controller what do I need to look at to make sure they are compatable?
5. If I upgrade my hub motor do you normally just restring your spokes or get a bike shop to install it or do you have to get it pre-strung on a rim?
6.If I am going to upgrade the controller, screen, and hub what order should I do them in?
7. How do I make sure I don't over run the hub motor and burn it out? I am looking at a 1000w sustained motor with peak about 1500w
If you have any experience in any of these questions please would love to hear your ideas!
