Voltage bounces around and cuts on BBS02.
Sometimes the display will read true voltage (~48v for the 13s) leading me to believe some electrical wire/element is loose. The battery has a built in battery indicator (indicating ~75%) so I dont see the need to test each cell. I dont have break/shifting cutoff sensors. I did bang the bottom of the motor/controller going over a log.
To fix, I'm considering 1) Resetting the firmware via USB 2) buying a replacement controller (if its faulty) that can handle more amps.
Any ideas on how to troubleshoot?
