I recently purchased a Vado 4.0 SL. While it does not include the Turbo Connect Display, a 2 piece mount was included in the package I received from the LBS. It is not a clamp on to the handlebar map and included a flattish plastic piece that the display or garmin can be mounted onto as well as a metal piece that has a hole in the center with two tabs extended horizontally.
Does anyone know if this is normally included with the 4.0 and how would it be attached to the bike. Does it somehow need to be attached to the handlebar/stem bolts?
