voidedwarranty
I would stick to 18t based on your calculations that puts you at 15 mph at 60rpm in 3rd gear. The BBSHD will throttle well past that if needed but going much smaller with the rear cog will start lugging it in 1st gear. Being that the motor is cadence based, it will always want to keep you going past your comfort zone unless you program the assist to drop off at the correct motor speed that correlates to the desired comfort zone.I only use the throttle to get the bike rolling (due to my weak left leg.). I normally ride in PAS 1 & 2, with PAS 3 very rarely for big hills, and prefer to ride around 13-16mph.
Original rear cog was 26t and front sprocket was 34t. I couldn’t possibly keep up with the pedal cadence at road speeds, so I replaced the front sprocket with a 46t, then a 52t. Even with that, I’m pedaling too fast at 16-18mph to keep it up for long.
If I am using unlimited throttle, top speed could be as high as it’s safe, but it not a big concern as I’m not going to use it much. But I’m coming off multiple Honda Sport Touring and Adventure type motorcycles so no matter how fast it goes, it’s not much in comparison.
There are threads on this subforum that go into great detail regarding BBSHD PAS settings. Thanks to @Gionnirocket and @AHicks
