Alaskan
I have been laid up with an inflamed tendon, posterior tibialis, affecting my left ankle and foot.  At one point early in the week I was using a walker and could put no weight on my foot.  Some good PT plus some even better TLC at home and am 75% back.
In the meantime. I spent some time in the shop messing around with my bikes on a rolling stool with adjustable height. the biggest changes were on my 2018 dual battery, derestricted, delight mountain.
My tendon is nearly healed up now. Rain in the forecast. Eager to ride my updated and improved bike.
- First I replaced the KMC chain11EL chain after almost 1,400 miles.
- Then a new 11-46 Sunrace cassette and a new Sram 18 tooth front chain ring, then fine tuned the derailleur.
- Next was a pair of the new Schwalbe Johnny Watts in the 27.5 x 2.6 size with Tubolito tubes and Tannus Armour.
- I replaced the Fox Float Performance front fork and Fox Performance rear shock with Fox Factory, Kashina coated versions with 10 .extra mm of front fork travel to raise the bike up a bit and reduce pedal strikes.
- I also moved the Supernova M99 Pro 45 down from the handlebars to a mount the rides the bottom of the steerer tube.
- Finally the fork and shock off of the Delite, were serviced and installed to replace the Suntour/Xfusion on Nancy's Homage.
