Thruttle prob. doesnt work, self learning mode spins wheel, normal mode doesnt
nejcraft
Europe
Hello
recently I ordered this https://www.aliexpress.com/item/3296427 ... 37704F5wfG
The wiring for some reason is a bit different(the yellow and black wires are split see my picture)
I connected the motor wires, battery and screen.
Started the self learning,
Connected wires powered up, wrong direction disconnected reconnected, right direction, disconnected turned off.
Turned on, Now when I pull the trigger it doesnt work.
Your door lock wire has to be connected to the battery for the controller to work. Maybe the Self-learn doesn't require that,
You didn't say that. Also, the 4 wire throttle doesn't match the advertisement.
Do the wire colors on the throttle match on both sides of the plugs?
Try powering down, then disconnecting the self learn.
Well I cant confirm the throttle actually works but the display part does. Its 5 wire, throttle + display combo(qs-s4) and yes it matches
