Enargins
I was looking to buy a Sunpost SP12 NCX seatpost. But then I found out you're supposed to take it apart, degrease it, apply new grease to the coil, and lubricate the joints every 300 miles!! That's too much work for me! LOL
Does anyone do that? I pictured buying this and just using it forever, not having to take it apart and clean it and degrease it every 300 miles. Is that something that's actually done?
Also considering the Thudbuster, which seems a lot better, maintenance-wise. According to the Thudbuster manual, the only maintenance required is:
1. The pivot washers should occasionally be lubricated with a light oil.
2. The skewer and elastomers must be lubricated periodically with grease. Apply grease to the shaft of the skewer and to the
ends of the elastomers.
That seems a lot saner to me! LOL
I'm interested in hearing people's opinions about these products, as well as whether maintenance is actually done, and how often.
Suntour manual (maintenance on p. 5) (Link Removed - No Longer Exists)
Thudbuster instructions (maintenance on p. 2): http://www.canecreek.com/wp-content/uploads/2018/02/THUDBUSTER_ST_INSTRUCTIONS_11-2013-v2.pdf
Thanks!
Thanks!
