Step-Thru
Trek Allant+ Lowstep
Workcycles, the Dutch cargo bike company, have revamped their line. Among the changes they are introducing Bafang BBS02 powered ebike versions they will ship to the US, and switched to using disc brakes. All good changes. This example is the Workcycles Fr8 MAD Family, with Enviolo CVP and 612wh battery:
Giant Explore E+2 STA. For MY2021 Giant address the shortcomings of their Explore E+ offering for the US market by doing what they should have done all along and bringing in the version previously available everywhere else in the world, the E+2 version that comes with essential commuter accessories: lights, fenders, and a rack. Plus they upgraded the battery pack to 500wh
The Breezer Powertrip is an OK town bike, but even with the larger 500wh battery IMO it's not worth $1,000 more than competitors like the Gazelle Medeo T9 HMB step through that uses the same Bosch Active Line Plus motor. For the same $3,500 MSRP of the Breezer you could get a 2021 Cube Nuride Hybrid Pro 500 Allroad which is an upgraded trekking type town & trail model with a 100mm sprung fork v 63mm; Bosch Gen 4 CX (85nm) vs Bosch Active Line Plus (50nm); much wider range cassette for hill climbing; larger brake rotors; wider tires; integrated powertube battery pack; etc).
Two new-to-the-US Gates belt drive equipped models from Gazelle
Gazelle Ultimate C380 HMB, with an Enviolo CVP and Bosch Performance Line motor
Gazelle Ultimate C8 HMB, with a Nexus 8 IGH and Bosch Active Line Plus motor
Cero 1.2 an update should be coming in Spring 2021 for this cycle-truck style ebike with a new drivetrain comprising Gates belt drive, Shimano E6100 motor, and Inter-5e IGH
Serial 1 RUSH/CTY STEP-THRU
https://www.serial1.com/rushctyst/
Tech Specs
The sophisticated commuter. The RUSH/CTY model is a premium, full-feature eBicycle designed for adventure-seeking adults ready for more-convenient and fun commutes, reduced riding effort and easier access to healthy lifestyles.
Motor
Motor Type
Brose S-Mag, brushless internal rotor, mid-drive mounting
Maximum Assistance Speed
20 mph (US)/25 kph (EU)
Motor Power
250W (continuous rated power)
Torque
90Nm/66 ft. lb.
Range
Battery
529Wh, integrated, removable
Controller
Brose Display Allround
Range
30-90 miles
Depends on mode and terrain
Charge Time
0-100% charge = 4.75hrs
0-75% charge = 2.6hrs
Drivetrain
Auto-Shifting Hub
Enviolo™ Automatiq intelligent auto-shifting hub
Final Drive
Gates™ Carbon Drive belt
Torque
90Nm/66 ft. lb.
Frame/Components
Frame
Hydroformed aluminum, welded construction, internal routing
Wheels
27.5 x 35mm alloy rims and Sapim stainless steel spokes
Tires
Schwalbe Super Moto-X 27.5 x 2.4-inch
Weight
59.5 lb./27.0kg (Size Medium)
S – 59.0 lbs
M – 59.5 lbs
L – 60.0 lbs
Fork
Aluminum
Rack
Integrated front and rear
Rack Capacity
10kg capacity each, front & rear racks
Frame Sizes
S, M, L
Brakes
Hydraulic four-piston-caliper disc brakes front and rear, 203mm X 2.3mm “heavy-duty” rotors
Fenders
Color Options
Gloss White
Gilded Denim
Matte Black
Gloss Midnight Black
Lighting
LED Front Lighting
LED Headtube Shield Signature light
BAF™ LED Headlight
LED Rear Lighting
Integrated taillights with brake light
Signature Shield Light
Norco Indie VLT 1 ST, powered by the Shimano Steps e6100 motor and 504wh battery. A dropper seat post is an interesting feature on this model.
Hase Pino Steps 6100, this recumbent front seat tandem has been updated with the Shimano Steps e6100 motor and larger 504wh battery
Frameset
FrameHigh-performance hydroformed alloy, Removable Integrated Battery, Range Boost-compatible, internal cable routing, Motor Armour, post-mount disc, 135x5 mm QR
ForkSR Suntour Mobie25, coil spring, tapered alloy steerer, preload, rebound, lockout, post mount disc, 100x15mm thru-axle, 50mm travel
Wheels
TireSchwalbe G-One, 650Bx57c
Drivetrain
ShifterShimano Alivio M4000, 9 speed
Rear derailleurShimano Alivio T4000, long cage
*CrankSize: S, M
ProWheel alloy, 170mm
ProWheel alloy, 175mm
ChainringProWheel 40T narrow/wide steel, w/alloy guard
CassetteShimano HG200, 11-36, 9 speed
ChainKMC E9S, 9 speed
PedalBontrager Satellite City pedal
Components
SaddleBontrager Commuter Comp
SeatpostBontrager Comp, 6061 alloy, 31.6mm, 8mm offset, 330mm length
*HandlebarSize: S, M
Bontrager alloy, 31.8mm, 15mm rise, 600mm width
Bontrager alloy, 31.8mm, 15mm rise, 660mm width
GripsBontrager Satellite Elite, alloy lock-on
*StemSize: S
Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 60mm length
Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 70mm length
Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 90mm length
HeadsetFSA Integrated, sealed cartridge bearing, 1-1/8'' top, 1.5'' bottom
BrakeShimano MT200 hydraulic disc
Brake rotorShimano RT26, 6-bolt,180mm
Accessories
BatteryBosch PowerTube 500
ChargerBosch standard 4A (100-240V) charger
ControllerBosch Purion
MotorBosch Performance CX, magnesium motor body, 250 watt, 85 Nm, 20mph or 32km/h max assist
*LightSize: S, M, L
AXA Blueline taillight
Size: S, M, L
Herrmans MR8
KickstandRear mount, alloy
Cargo rackRacktime Lightit
Weight
WeightM - 24.86 kg / 54.81 lbs
Weight limitThis bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 300 pounds (136 kg).
Ribble CGR AL e Step Through – Sport Shimano Tiagra From: US$2,645.50
https://www.ribblecycles.co.uk/ribble-cgr-al-e-step-through-sport/
Everything about the bike is designed to inspire confidence, from the easy access, hop on, hop off design to the comfortably upright riding position that provides you with a great view of your surroundings. Gone are the days of luggage getting in the way, with a step through design that offers plenty of leg-over clearance.
  • MATERIAL
    6061-T6 Aluminium
  • MOTOR SYSTEM
    MAHLE Ebikemotion X35 250W
  • BRAKES
    Disc
  • WEIGHT
    14.1kg/31lbs
Groupset
Shimano Tiagra 2x10 Speed
Shifters - Shimano Tiagra 4700 STI’s.
Brakes - Tektro MD510 Mechanical Disc.
Chainset - Shimano Tiagra 4700 50-34T.
Bottom Bracket - Shimano Press Fit BB71-41B, 86.5x41.
Cassette - Shimano HG500 10-Speed 11-32T.
Chain - Shimano HG54 10-Speed.
Rotors - Shimano RT-66 6-Bolt 160mm.
Front Derailleur - Shimano Tiagra 4700 Braze-On.
Rear Derailleur - Shimano Tiagra 4700 Medium Cage.
Drive System
Control Button - iWoc ONE Top Tube Mounted Control Button.
Hub - MAHLE Ebikemotion X35 M1, 36V/250W.
Battery - Panasonic 36V/250Wh, 18650GA-10S/2P.
Wheelset
Wheels - Mavic Aksium Elite Evo UST 700c Disc.
Tyres - Schwalbe G-One, Tubeless-Ready, 700x40mm, Black/Tan.
Frameset
Frame - 6061-T6 Heat Treated Aluminium, Seamless Welds.
Forks - Full Carbon Monocoque, Tapered Steerer.
Headset - LEVEL H56 Integrated, Black.
Finishing Kit
Bars - LEVEL 1 6061 Alloy, Black.
Stem - LEVEL 2 3D-Forged 6061 Alloy, Black.
Bar Tape - LEVEL Cork Ribbon, Black.
Seatpost - LEVEL 1 6061 Alloy, 27.2mm, 350mm, Black.
Saddle - Selle Royale Vivo Ergo, Black.
Pedals - Plastic Flat Pedals, Black.
Weight
Approximate Weight - 14.1kg/31lbs.
Lemond Dutch Starting at $4500
https://lemond.com/dutch
Our Dutch can take you anywhere – far beyond the city to the hilly country if you like. Weighing in at 27 pounds, including the motor and battery, the Dutch can be lifted by anyone, whether upstairs, into the car, or onto a carrier, and if you exceed the battery range, have no fear that you can ride it home. -Greg LeMond
