rochrunner
- USA
- City
- Rochester Hills MI
30 does seem a bit low unless the Como tires are really big.I tend to have a high seat for good leg extension.
Yes, all mid drives.
The Sequoia is an XL, with rear rack and Thudbuster seat post, 34#. The Specialized Epic Expert carbon is 28#, the Vado 5.0 L is 57#. That 28# is reeeaaal nice. I was really surprised at what 20+# feels like on a bike, feel sorry for those guys weighing in the low 200's. That's a lot of weight to move around.Your Sequoia was that heavy? I never weighed mine, but I found about as big a difference when I went to a carbon Cdale Synapse and saved probably 15lbs. It was an eye opener!
By the way, even with assist it's a good idea to shift down as if you were on pedal power; if the motor has to work hard against a higher great it's taking off range just like it would wear you out.
Hmmm, better check my torque wrench bit length...@Sierratim & @TS25, many many thanks again! You are the Vado real experts and always come with the accurate information! I'd like especially thank to TS25 as he can always find something in Germany I can buy and get it fast.
The delivery of the Lightning specialized axle from The Robert Axle Project was lightning fast. It was delivered by Bike24 in just 21 hours!!!
The LIG506. I took measurements with a caliper and the axle will fit my Vado. Specifically, the tapered spacer is very important. I will bring it to my brother in the evening.
My brother told me why the original axle quit. The bolt-head socket is very deep there (10 mm). The bit of the torque wrench is much shorter, so damage of the socket was inevitable.
Once upon a time, a noisey freewheel was a sign of a top-quality hub. My MTBing sons say no longer, the best are quieter now. So do I tell the best from the cheapest now? I'm sooo confused...Anyone else find that the freewheel ratchet on the Vado is a bit on the loud side? I sort of thought this and then a guy riding next to me commented on it (said he thought I had a playing card in the spokes). This came home to me the other day when I took my Crosstrail out and found it almost silent when coasting. FWIW, I had a set of Mavic wheels on one of my road bikes a while back and they were also noted for having noisy freewheels.
I think @Stefan Mikes has the right idea, an ebike for every use! Now if I can just get the boss to agree...On my ride through a favorite park this morning I determined that the Vado is definitely not a trail bike, at least for these trails. The weight and long wheelbase make it feel slow to respond, and the OEM tires are tricky on loose gravel. Especially on a couple of downgrades (not that much of a hill), it was difficult to keep the front wheel from plowing due to the extra weight on it. Definitely not fun, but thankfully only a couple of short sections.
If you mean the freewheel in the motor then yes, it is noisy.Anyone else find that the freewheel ratchet on the Vado is a bit on the loud side?
Why d'you think I've bought an e-MTB?I think @Stefan Mikes has the right idea, an ebike for every use! Now if I can just get the boss to agree...
Happy "it all came together" for you!If you mean the freewheel in the motor then yes, it is noisy.
@Sierratim and @TS25 , you're both wizards! See The Robert Axle Project LIG506 axle in action on my Vado... It's perfect! It's better than the original one! The head socket is properly shallow and it is for the 6 mm Allen key, not 5 mm.
Yep, I put it up on the stand. It's the best working height for me. Others suggest that you zip tie the chain ring to the crank and turn it backwards that way.What do you guys do about cleaning and lubing the chain if you can't spin it backwards? I'd hate to have to put it on the workstand for that.
Somehow I'm surprised that works but I might try it. Thanks.Yep, I put it up on the stand. It's the best working height for me. Others suggest that you zip tie the chain ring to the crank and turn it backwards that way.
Had a rear wheel blow out at mile 14 of a 22 mile ride today. I suspectvthe bead of the Trigger tire let loose; the tube was split may be 16 inches near a seam. Glad it wasn't the front tire!
Pulled over, walked to a bit of shade next to a fence and got to it. 17 minutes, a new tube, 1-1/2 CO2 cartridges, and a Grease Monkey Wipe and i was off again. Didn't need the tire levers as the blow out took one tire bead entirely off the rim. No rim damage, I think I came to a stop on the tube between the rim and the road. Glad I had the full flat repair kit though.
Enough excitement for the. It must be beer-30 some where...![]()
Flats suck!Same here Sierratim!
Got a piece of glass jammed in the back Trigger tire. By the time I stopped to check, the hissing sound was pretty distinctive. Fortunately only a few block from home. Locked up the bike, walked home, got the car and off to my lbs. They fixed it in 10 minutes! Then off to the trail head and I still rode 38 miles.
I'm with you on that beer idea!!![]()
