Good day,
My wifes bike battery 2018 Vado, after charging and disconnected from charger, displays all green indicator lights when I turn on. Normal.
The bike display illuminates, then goes dark except for only the lowest battery cell illuminates and pulses on and off while all the green battery lights remain on steady.
I swapped battery to identical Vado of my bike and the issue followed the battery, to this bike.
Tried to ride to see if motor would respond to speed selection, up or down. No active motor assist.
Sent email
Specialized RideCare, no response in a week.
Took to LBS (Specialized Dealer) had firmware updated, did not help. The LBS is talking to Specialized Vado engineer, he thought wiring harness until informed the issue followed battery between bikes. He is too research and contact LBS sometime.
Talked to two Specialized bike shops owners I know, they also are stumped.
Can not find Specialized instructions to properly / fully discharge the battery, or perform a reset.
Known solution or if you know a resource that can help I would appreciate a response.
I have posted to maintenance form section and hope this is a connection to Vado section. Yes, I am new to forum.
