Shock adjustment and controller manual help needed for Himiway Cruiser help required
alatgreir
Is there any info available regarding how to adjust the shock setting on the Himiway Cruiser. The manual included has little or no info on adjusting the shock or how to update the speed setting on the controller.
Other than that after a few short rides this seem to be a good bike. I have two Aventon pace 500's which are great for paved use and really love these. I bought the Cruiser for off road/trail use.
thanks, any direction to finding more useful info would be greatly appreciated
Here is how to adjust the speed settings. The fork.....you simply turn it. One way is on or active the other is off or non-active (solid front). At least that's what it is on mine.
thanks, it was very helpful. On the shock the setting is only on the right side, correct?
al
al
Yes. That is the way mine is.....only on one side. It's effectively just a "lockout". A better quality product would allow you to adjust the rebound and dampening. A cheaper fork, like on the Himiway only allows you to make it active or lock it out. It works fine for it's purpose.
Not sure if you guys are aware of the left side Pre Load Adjustment?
