RX PRO 19.2 ah battery hits 100 km on one charge
Spatzi
19.2 ah battery. This is around my fifth battery charge on the bike. Hit 100Km today. This is over 5 trips. 98% of riding at pas 1. Throttle used about 3 Minutes. Weight: 177 lbs.
August 3- ubc heavy trails 38km, battery 65%
August 5 - Stanley park trails and road 17.9 km (total 55.5) 55%
August 6 - Stanley park road 12 km (total 67.4) 25%
August 9 - false creek pavement ride (slow) 14.5 km (total 81.9 km) 46.4 volt
August 10 - Stanley park trails 17.6 km (total 100 km) 44.2 volt
One green bar remaining on battery.
Last time I hit 70 km and was down to 5%, but I did not use voltage view.
it is an interesting test/measure
Here's some of my result with a 17AH however (Rize Mini), I recharge as soon as I am back so the precision is not very good if I don't do a long trip
36.2KM 60% (A lot of wind and more throttle)
26KM 93% (pedaling a lot)
33KM 87% (pedaling a lot)
34KM 66%
24KM 74%
25.8KM 81%
My result are not linear but I think it's due to the battery taking a while to register % when the voltage is higher, I am probably going to measure voltage for better precision
Lithium are better if you re-charge after each use not letting it discharge too much unless needed, it's not a bad thing to do discharge a bit more once in a while but it's definitely better to re-charge daily
How did you measure the voltage, is in integrated in the Baffand display or if you used a DMM ?
Your battery probably discharge slower in the last 60% than mine, I evaluated I could do maybe 80Km on mine
