Rear motor removal fat bike
jangles
I want to install a mid drive in my BTN fat bike and remove the motor from the back wheel . Would it be easier to just buy a whole new wheel or have someone re-spoke my wheel after motor removal ? Thanks for any input .
I dont have a problem with that but I dont know which one or what hub to use . Is there a way to tell with these things ?
Need to know the size of the wheel (I assume 26"), the width of the hub (you can measure the inside distance between the dropouts, where the axle sits in the frame), and how many gears/cogs are in the back.
With a tape measure it appears to be 7" and has 7 cogs and a brake disc . It is the BTN AWD fat bike if that helps . And yes it is a 26x4 . Thanks for your help .
