Hi, I had recently purchased Radmission worked well for some time and then one day it started to malfunction.
Problem: After I power on, Throttle and PAS work well till I apply the brakes. Immediately following the brakes, the Throttle /PAS does not seem to be able to give enough power to make the wheel rotate. When I tested off-road (leaning the bike with the stand) I can see that using throttle after applying brake gives a clicking sound and after a drag, the wheel kicks off full speed so it feels like the wheel on road not have enough power to get off. Switch off and Switch on Throttle or PAS will work till I apply the brake. Also Front or Rear Brake same effect.
The only thing I can think of that happened was, I removed the rear wheel once to install fenders, but it worked for several days before giving me this problem. I have been with Rad power bikes support for weeks now and I have performed a. Remove all connectors, Remove Battery, press power button to make sure any static power is drained, and install everything twice so far with no luck.
video attached for reference
hoping someone more knowledgeable can help me here.
