Checked it today with a 70% charged battery. PAS 1 bounced between 32 and 64W, mostly on 32. So maybe 45W average? But I think the intent is PAS1 is the training wheels mode, that you use for the first 5 minutes then never go back to. But, if there's only 4 other PAS settings, it's a waste of a setting.
The rover does fine in ~60W "walk" mode, scoots up stairs and drags you up steep hills. I just wish there were a 1/4 and 1/3 power option for longer rides. I'd also be willing to give up the PAS 4 (2/3rds power) to get those, since I usually ride at PAS 3 (1/2 power) and only use PAS 5 (or just twist the throttle) to catch a green light or to pull out of a bonk on a hill.
I am aware of the Bolton upgrade option. 1500w sounds exciting until you think about your range (10 miles?), and that urban biking at 25mph is already scary enough. I'm still glad the option is there.
Speed is dependent on voltage, since you are not upgrading the battery top speed is unchanged. However on inclines you will have more torque because the Bolton controller can provide more current.
In practice you probably would use that extra torque for short bursts only, range should not change that much.
