Red light NOT on is most likely a sign the connector isn't plugged in correctly. If that's right, then there's no power going to the sensor - likely a controller issue to my way of thinking.
C1=3 will work if the magnet ring is on the left side of the frame. You need to use 5,6, or 7 if it's on the right (gear side) in my experience.
