Mike leroy
In my case, I need power assist to behave like a turbo-charger, not cruise control. I would like to use power assist to function like a transmission, rather than energy conservation. Match torque to RPM to optimize power. I was told transmission-like functionality is not possible.
My option is to turn pedal assist off (PAL 0). I will use the throttle as a turbo charger in the few, short, extremely steep sections.
To my way of thinking, throttles are better than pedal-only systems. At the very least, a throttle enables you to optimize the tradeoff between speed and battery consumption to find the best balance.
The BBS02 allows nine (firmware update) levels of assist to be configured. Each assist level specifies the ratio of leg/motor power, not wattage. Wattage is not a parameter because the controller software factors cadence into the algorithm.
Both torque and gear shift sensors will be available for BBS02 or BBS03 from lectriccycles.com in the near future. Only a controller replacement is necessary. Additional sensors improve gear shifting, but make power level configuration even less possible.
My main route is 2700m or 1.7 miles and 600 foot elevation change. My trip is entirely up or down a canyon, not rolling hills:
What is the steepest you can climb?
- How to configure PALs to correspond to hill steepness optimize the entire power system, rather than just battery consumption?
- Is it wasteful to use power assist in a high gear?
- 10% grade for 400m
- 02% grade for 400m - power unnecessary.
- 18% grade for 250m
- 10% grade for 200m
- 05% grade for 500m
- 02% grade for 1000m - power unnecessary.
