Hey guys - I did a video of how the PAS levels work with the new firmware -which is based on WATTAGE OVER PAS. The older firmware is based on SPEED OVER PAS.
In simple terms - for example - PAS Level 2 caps out around 150w (out of avail 750w). It doesn't care what speed you travel be it 3 mph or 20 mph. It will always give you about 150w to "assist" you. The older version of the controller was based on level. For example PAS1 would cap out at 10mph and it didn't care how much power it took. All the controller wanted to do was get you up to 10mph and keep you there. If you pedal faster/over 10mph - all power is cut off and you're 100% under your own power. So in a way the new firmware is a bit better depending on situation.. less jerky.
Anyway - here's the video to demonstrate the newest firmware. This is confirmed by Rad Power Bikes as I complained to them and they assured me this was properly working (I showed them the video)
