New to Ebikes and Looking for Prospects
Zoumios
Absolutely new to Ebikes, and this website, and with that comes outstanding ignorance.
I'm looking for an Ebike that can make it up hills with a bit of ease (so mid-drive?), that doesn't have too many wires and cables, uses a hydraulic brake system, has a rear and/or front racks, doesn't make much or any noise when using the motor, and looks "professional" or "polished."
This would be a commuter/urban/cargo bike. I am in the USA, male, 5' 11,'' 160 lbs.
I've looked at how some of the specs for an Ebike effect performance (motor output in watts, battery voltage in amp/watt hours, motor torque in newton meters), yet I don't know to what degree all of these matter. I've also seen some bikes were the variables are almost identical yet the mile range difference is drastic.
I also don't know what brands are quality and which aren't. I also don't know how much I should be paying for anything.
I've looked at these bikes so far:
Faraday Cortland: (https://electricbikereview.com/faraday/cortland/)
Gazelle NL C7 HMB (https://electricbikereview.com/gazelle/nl-c7-hmb/)
Walleräng M.01 (https://electricbikereview.com/wallerang/m-01/)
The Faraday is what I first started looking at, but I have no clue if it has enough power or not/if it's worth the price. It is, however, quiet and looks amazing.
The Gazelle has great colors, but some of the main parts of the bike look non-durable or ready to break, there are many wires hanging about, and front basket is too clunky.
The Walleräng looks fantastic, has mid-drive, 500w motor output at max, and has (what I think to be) high quality parts and pieces, but it's seems a bit loud. Is that standard? This is the best ebike out of the 3 I have really examined.
For anyone willing to help me out, this is a sizable post, I am open to all knowledge of Ebikes, opinions on brands, opinions on bikes I've listed, and any suggestions you have of Ebikes that would be best fit for me.
Thank you in advance.
I wouldn't put much stock in the cortland, you're right a mid drive is generally better on hills, but would be less of a factor since you are pretty much the definition of an average size rider!
As far as mid drives, Bosch, bulls, Yamaha and shimano are the main motor motor manufacturers. Check out court's review videos of bikes with each as he'll describe their different characteristics. Aside from that, make sure it fits your needs, and if possible try to get to a shop to try bikes and but if it is a good deal.
Whether online or in store, consider the price negotiable. Don't pay msrp; if you aren't getting a deal, look elsewhere.
The quietest mid drive on the market at the moment is the Brose motor. If you combine the Brose system that with a Gates carbon belt and an IGH (Nuvinci, Shimano Alfine, Rohloff......) then you will probably have the quietest mid drive ebike you can get at the moment. If you want to research some Brose mid drive ebikes I suggest you check out the Scott E-Silence, Specialized Vado and Bulls Lacuba range. What is your budget.
