I'm still running the original Vee8 tires I installed back in Feb/17 on my two 2016 Rovers. I had less than 1000 miles on the rear Kenda tires before I needed to replace. I am between 2300-2500 miles per Rover with the Vee8 tires with the tires around 50% worn. I rotated the tires around 1500-1700 miles to even wear out. I was lucky and was able to find 4 replacement Vee8s on eBay over the last 2 years as down the road replacements. I'm still very pleased with the lower noise, high speeds, road/trail capabilities, long wear, and flat resistance with these tires (run around 21.5-23 psi).
