New and looking for a large step-through
Urchina
I had the chance to ride a first-generation ebike for a couple hours last weekend and it's made me realize that my bike future is in ebikes.
I currently commute 3 days a week (6 miles RT) on a 61 cm Workcycle Omafiets (classic Dutch step-through) and it's nearly ideal - except not electric. The reason I don't ride it 5 days a week is that one of my jobs requires a steep, long hill ascent and is 20 mi RT. I think with an ebike I could stop driving most days.
So - I want an ebike with all the great features of my current bike (upright riding position, step through, large frame). But I'm finding all the ebike info overwhelming.
Does anyone have any recommendations for a large frame step-through?
Thanks in advance for any help you can give!
A couple of step through bikes that come to mind are the easy motion evo street, and izip path+ bikes. The newest izip is a mid drive, which tend to do very well on hills because they take advantage of a bikes gearing. Easy motion bikes are very nicely designed with a frame integrated battery.
Either way, if you rode an older ebike (if that is what you meant by first generation), they have come a long way in just the last 2 years, and there are plenty more options that others will chime in with I'm sure.
Hi Urchina,
The bike you own is considered a "forever" bike, and is of high quality. And it seems you like it. Being a very large step thru, not sure there is an equivalent eBike step thru out there.
Since your commuting requirements are not that demanding, why not buy an eBike kit and have someone install it?
Don't know where you live so I can't recommend a specific kit but these type of specs should do the trick:
500w direct drive hub motor.. A geared hub motor will be smaller and lighter, but the gears do wear out.. For a daily commuter this is maintenance you don't want to face.. Direct Drive hub motors are known to last tens of thousands of miles. Suggest you have the motor mounted on the front wheel to balance the weight better, but the steering will suffer a bit.
36v 10 amp hour battery, mounted on a rear rack. You should buy a double decker rack that can hold the battery and leave the top free for a bag... The racks are usually available from the ebike kit vendor. A rear mounted battery is not ideal, but you're commuting and not running dirt trails.. PLus a step thru limits the options.
For the long ride with a long hill, buy an extra charger and leave it at that workplace.
Replace the tires with high quality tires and thorn resistant tube.. Suggest Maxxis Excel or Schwalbe Marathon.. A lot of people don't want to deal with a flat on their electric bike.
Have the bike tuned and replace the pads. go with Ergon handlebar grips.
The total cost for all this fun (depending on where you live) will be less than $2000. Don't go with cheap; it doesn't pay.
You will have a bike just like yours, only better!
JoePah and pxPaulx, thank you for your replies.
This is why I bought it. I LOVE this bike. I would change the gearing (mine has three gears and I wish the 8-gear had been available.) I looked for my bike for two years and ended up driving 400+ miles to buy it, since I planned on it being a lifetime bike. I have no desire to get rid of it. My bike in an electric version would make me the happiest.
I'm simultaneously researching this option, too. I found this thread on the forum and it asked essentially the same question, but I didn't find a follow-up.
I live in the Santa Barbara, CA region, if that helps. Los Angeles is about 2 hours away by car; I'm also able (and willing) to take the bike to the north San Francisco Bay area (Sonoma County). So my striking distance for an e-bike install is anywhere between Los Angeles and Santa Rosa, CA. For that matter, if the perfect shop was in San Diego, I'd haul down there, too. That covers most of coastal California.
500w direct drive hub motor.. A geared hub motor will be smaller and lighter, but the gears do wear out.. For a daily comuter this is maintenance you don't want to face.. Direct Drive hub motors are known to last tens of thousands of miles. Suggest you have the motor mounted on the front wheel to balance the weight better, but the steering will suffer a bit.
What about a mid-drive motor? I like the idea of the motor working with my (admittedly limited) gearing. Any pros/cons here?
I don't care about a rear-mounted battery so long as I can keep my awesome saddlebags in place. I'm glad there are double-decker racks available.
This, unfortunately, is not possible. The long commute with the long hill is to a community college where I am an adjunct faculty member. I don't have an office and the campus does not have e-bike charging stations. There's no place for me to charge the bike there. So I need an ebike that can get me to that job and back (10 miles each way with long hill on the way there) plus let me run a few errands around town (I want to quit driving, and the days I commute there are my errand days for things in that part of town). Upsize the battery? The e-bike dealers here have been recommending 48v 15 amp systems for that particular commute and my planned errands -- but I realize they're also benefiting slightly from selling a larger (more expensive) battery system. Thoughts?
Replace the tires with high quality tires and thorn resistant tube. Have the bike tuned and replace the pads.
Bike currently has Schwalbe Marathons. Have ridden the bike in a variety of environments (including flat off-road) for three years and have never had a flat. Love those tires. Front brakes are rollerbrakes (not calipers) -- how would this affect a hub-mounted drive?
Promise? This would be ideal. I have slight anxiety about getting a kit and having someone install it -- what if they messed up my baby and I never got her back? I realize this is unlikely -- nobody will be drilling holes in the frame and it can be put back together. However, I haven't yet had to look for a bike shop that can do maintenance on my bike -- it's been hassle-free -- and one of the trusted shops in town hasn't had any experience with the Workcycles.
Thanks very much for the advice. I'm still getting adjusted to the price tags on the e-bikes; it feels like a big investment and I'd like to not have regrets afterwards.
Not exxactly sure how far Santa Barbara is from LA.. Luna Cycle can't be far from you, and they are quite reasonable.
http://lunacycle.com/ give them a call. They will love to handle a bike like this
Don't worry about ruining your bike with an ebike kit.. It's all bolt on.
And about charging your bike. You don't need an office just the same outlet you run your laptop from.. Classroom, lab etc... It would take an hour to give you enough charge to get home.
I would recommend looking at the Kalkhoff Agattu, it's available in a large and XL size. You can also look at the Cannondale Mavaro which is available in a 62cm low step. I'm not sure which dealers are in your area but if you go on the brand websites you should be able to locate some.
Urchina, did you see the post of the new ebike dealer in Santa Barbara ? Electricbikezzz.com is their name if I recall. They might be able to help you.
