Absolutely... It's more like data entry.Yeah, it's not programming. It's calling up a screen and plugging in numbers. You get someone else's numbers, like the GionniRocket package, and you put them in.
Sure.... I'll help.So I'm intrigued about the reprogramming. Is there a thread you can point me to? And how much does it cost? If you are going to ream me for being a social media idgit then please do me the courtesy of a reach around.![]()
smh....Whilst sure you could turn down the levels if the controller lets you, a lot of bikes don't... like my Aventure... and really why cripple the motor when you could just adjust the gear ratios?
It's something I knew I was going to have to do with mine because I rarely find an off the shelf bike of any type that fits my strength, stance, and cadence "out of the box"... motorized or not. They are always weaksauce on the high end and leave me spinning my feet in circles doing nothing on the low.
To me the answer isn't turning down the power, it's getting the right gearing front and rear. Thus the first thing I did on my Aventure was to swap the front chainring from a piddly little 44 (that their website says is a 46, just noticed this... maybe it's because I got the 'small") for a 53 tooth. Likewise I swapped the 165mm cranks they claimed were 170 for actual 170's (in billet aluminum taking 4 pounds off the weight of the bike)
Took things a bit too far on the low end once I tried riding without power, and there was a hair more room on the high end, so I swapped the rear cassette to a 11:36 instead of the stock 12:32.
The 53:11 is a perfect match for the max power of the motor -- for me. Likewise 53:36 is spitting distance from the stock 44(46?):32 it came with making it possible to push the 70+ pound SOB around when you lose power.
The bike no longer feels like it's trying to race out from under me maintaining back-pressure on the pedals so I'm always contributing to the ride.
We're not all the same height, size, weight, strength, and so forth, so the idea that the gear ratios a bike comes with are right for every rider is absurd, and in my -- admittedly limited -- experience these e-bikes seem to have massive mismatch between drivetrain ratios and motor power on the high end.
Rather than screwing around trying to turn down the power, adjust the drivetrain to match your motor and yourself. That way you get the full potential of both. It's like $50 worth of parts, $30 worth of tools you should probably have as a bike owner anyways... and more than worth the time and effort.
Agree with the gear changes because they are rarely correct, but I have an issue with doing that instead of turning the power down when the issue is the bike is ALREADY going too FAST. For those trying to maintain good control at speeds under 8-10mph, like those you might encounter on a multi use path (MUP), it's about the power the bike is making (too much), not the gear ratio.Whilst sure you could turn down the levels if the controller lets you, a lot of bikes don't... like my Aventure... and really why cripple the motor when you could just adjust the gear ratios?
To my thinking the ideal in that case is to get the correct gear ratio and assist mode. I think since I've only used cadence sensor bikes where the PAS sets the top speed not the power applied, I'm probably looking at it differently from those who's controllers actually vary the power.For those trying to maintain good control at speeds under 8-10mph, like those you might encounter on a multi use path (MUP), it's about the power the bike is making (too much), not the gear ratio.
And there we have it... You're speaking with authority when you have no experience with what is being discussed.To my thinking the ideal in that case is to get the correct gear ratio and assist mode. I think since I've only used cadence sensor bikes where the PAS sets the top speed not the power applied, I'm probably looking at it differently from those who's controllers actually vary the power.
I mean with my Aventure -- much like the Nakto before it -- I want 8-10mph, I set assist 2, 4th gear (53:20), and it's a comfortable cadence. No changes to the controller needed.
Dicking with the motor controller seems unlikely to do that unless you're screwing over what the motor can deliver... but again not that my bike even lets you do that!
I mean it's what I started my post with, a lot of bikes don't even let you change that stuff. You're locked out. Period.
Even so, I take it torque driven or other motor controllers behave differently on that when it comes to power adjustments? My Aventure seems to ramp up the power slowly but it's not based on cadence or input. Once it hits peak power it provides that power until you hit the cadence limit. Thus the only solution when it keeps racing out ahead of you is to up the gear ratio.
No, you're just being an ass, because how dare in a topic other people might find somebody offer an alternative when accessing the controller isn't an option or available. Or worse have the gall to present an option or opinion that contradicts yours. Much less try to make recommendations to improve comfort and power, in a way that may in fact be more efficient than the games suggested in this thread.And there we have it... You're speaking with authority when you have no experience with what is being discussed.
You're good for a laugh... That's for sure.No, you're just being an ass, because how dare in a topic other people might find somebody offer an alternative when accessing the controller isn't an option or available. Or worse have the gall to present an option or opinion that contradicts yours. Much less try to make recommendations to improve comfort and power, in a way that may in fact be more efficient than the games suggested in this thread.
I freely admit that in terms of motors and controllers I'm a bit of a rookie, and yeah I'm 20 years behind on bike tech. But it's shmuck kibitser alter-cocker attitudes like yours that drives beginners and experts alike out of forums like this entirely!
Gey strashe di gens.
