Alaskan
The one thing about the OEM drive train on this speed version of this bike that I felt compelled to change was to slow
down the cadence in the mid 20mph range in the smallest, 11 tooth cog.
Shy of scrapping the GRX setup and putting a Sram Eagle 12 like the Neo 1 or a 2x1 like on the Neo 2. The easiest path
was to put a larger chain ring on the bike.
So I found a 46 tooth to replace the stock 44 tooth that came with the bike. I then replaced the 11-42 cassette with a
Sunrace 11-46 which works surprisingly well with the stock derailleur despite the fact that Shimano specs it out to a
max of 42 teeth. Another factor that helped was replacing the stock 42mm tire with a WTB Byway 650b x 47.
The bottom line is that in the final 11 tooth cog I am spinning at 70 rpm while traveling at 25 mph whereas OEM I was
spinning at 80 and can sustain this speed for miles on flat ground with the assist set at tour.
Mission accomplished. I took an outstanding bike and made it even better, IMO.
I completed the installation of the 11-46 tooth cassette and new longer chain. I installed the Sunrace CSMX8 in the black
color It is a bit less money in straight silver but looks way cooler and does not look dirty so quickly. I have been using this
cassette for over two years on another bike that has a Shimano XT group set and found that it is at least as durable and
offers crisper, more accurate shifting.
from our covid shots. Tis was ordered on Sunday and it arrived in Bellingham Washington on Thursday. I swapped it out
with the stock 44 tooth before dinner. Test ride probably won't happen for a few more days. The chainring delivered to
the door was $69.83. Kudos to the .ebay seller, Velozone Cycles...
Reply
Report Edit Delete
www.sunrace.com
I used Shimano 11speed chain (CNHG70111) 116L w/QuickLink Chain NIB https://ebay.us/I0vczb
It did take lowering the derailleur a bit to accommodate the 46 tooth cog, using the stroke adjustment bolt found on page
17 of the dealer installation pdf manual - copy attached below. I have not road tested it but it shift up and down well on
the stand. I hope to get out and test it in real life tomorrow.
Here are two photos, one in the smallest cog and one in the largest. This took the gear range from 382% to 420%.
I used this bike gear speed calculator https://www.bikecalc.com/speed_at_cadence
I came up with the following results you can enter your own data and change speeds from mph to kmph.
This is the result with OEM drive train as per spec
This is the result with my mods. Everything is entered accurately except tire width which were in preset increments.
Mine are 47mm but 50mm was the closest value I could select.
Holy Mackerel!!! The 46 tooth chainring arrived from England yesterday. It was waiting on our porch when we got homeFSA G3/4 Bosch EBike Bicycle Cycle Alloy 104 BCD 1X11 Chainring Black
FSA G3/4 Bosch E-Bike Bicycle Cycle Alloy 104 BCD 1X11 Chainring Black | eBay
BCD 104mm. With chainring bolt / nut. Motor Type:- Bosch.
ebay.us
Reply
Report Edit Delete
SunRace | CSMX8
